2012 RCSB 416ci TVS2300
#141
500-600 miles only
so called balancing lol
bearing to rod journal and bearing to rod clearances were stock.. with aftermarket bearings.. he did not machine anything at all just the block.. he screwed that too.. 6 thou piston to wall clearance.. lets hope this doesn't happen again
burned your cash on that dump funk , good luck with the new plan
btw what shop did the 6.2 assembly for you ?
#144
He said.. "ur pistons were too small and th rods suck" the pistons were 4.070 which are .005 more than stock.. He was the one who honed the block too much come'on 6 thou of piston to wall clearance? And drilling holes under the pistons to balance them.. He didn't even balance the crank or line hone the mains
Im getting a new shortblock soon stay tuned for the pictures
#145
#147
#148
#149
You had the exact same size bore and pistons size I do. Send your engine to Alaska and have Roger build it for you LOL. My engine runs amazing, I am just worried about everything behind it now that's still stock
Sorry to hear about what happened but looking forward to the next setup
#150
just going with a built 6.2 shortblock with 9.5:1 compression
