2008 yukon build.....Err uh mod thread
Old Jun 5, 2018 | 11:26 PM
  #511
Wolftrk99's Avatar
I know....i should replace them all and i will but cost is prohibitive at the moment...need to get it back together and out of where it is so i can change jobs in a week and a half or thereabouts
Old Jun 5, 2018 | 11:28 PM
  #512
1FastBrick's Avatar
Custm2500's Rude Friend
I went back and you mentioned Comp 918 springs but not sure if that's what you got.
Lots of failures of the comps...
Old Jun 6, 2018 | 12:01 AM
  #513
Wolftrk99's Avatar
The 918s were a set i had laying around at one point i had on the other truck for a little while with the old xr275 cam i had before i swapped it out.... the springs inwent with were some pep or something springs, used same springs on the silverado and so far have had no issues, since i installed them, but then again the silverafo isnt vvt either
Old Jun 7, 2018 | 10:18 PM
  #514
Wolftrk99's Avatar
So..... uhhh, yeah i have this nifty little spring compressor that works awesome when the spring arent broken, anybody have any insight on how to get this broken spring off, the tool made the valve open when i started trying to compress the spring, the outer spring is in about 6-7 pieces, so....
Old Jun 7, 2018 | 10:20 PM
  #515
Wolftrk99's Avatar
Almost majes me want to pull the head off at this point.... but i will save that for when i am not trying to do this at a job i am about to leave.. and have a full set of springs to put on
Old Jun 8, 2018 | 11:28 AM
  #516
Wolftrk99's Avatar
In total the outer spring was in 5 pieces and the dampener spring ws broken as well
Old Jun 8, 2018 | 01:32 PM
  #517
Wolftrk99's Avatar
Oh the carnage
Old Jun 8, 2018 | 09:03 PM
  #518
1FastBrick's Avatar
Damn them cheap springs...
Old Jun 11, 2018 | 08:55 AM
  #519
Wolftrk99's Avatar
So i have been thinking about this spring issue the last couple days, i am wondering now if that spring hasnt been messed up since i built the engine, there was a bit of a miss i could never really track down and the engine had always been a little noisey which i just attributed to the pushrods..... either way she purrs like a kitten now, just need to find time to swap the timing chain tensioner and be able to afford a full set of valve springs, if for no ther reason than peace of mind!
Not to mention the leaking trans cooler line and fitting and getting the alignment straight on this damn thing.... finally!!!
Old Mar 4, 2021 | 10:40 PM
  #520
Wolftrk99's Avatar
So, just an update on this, 9/17/2020 i traded the yukon in on a 2019 Silverado
