2008 Silverado, 408, KB racing GT91 turbo kit
Old Jul 27, 2012 | 09:52 PM
  #231
03sierraslt's Avatar
Originally Posted by Atomic
The VE of the engine should not be affected by changing injectors, and therefor the VE table should not need to be modified much (or at all, in theory). If you replace injectors, and fueling is now off whereas it was close to perfect before, the injector data is wrong. Plain and simple.
There is no harm in changing the injector data, you can always change it back to whatever Jon said if it doesnt work.
I agree 100%. If the injector data is correct then fueling should remain correct, IDC should just drop. It doesn't always work out perfect but in theory that is the way it should be.
  #232
Is this a mail order tune?
Old Jul 27, 2012 | 09:57 PM
  #233
smokeshow's Avatar
Mod with training wheels
Wait, I thought you scaled for injectors with the MAF?
Old Jul 27, 2012 | 10:02 PM
  #234
sprayedenali's Avatar
so how exactly do i get the "right" data in there if what i have is wrong?
Old Jul 28, 2012 | 07:33 AM
  #235
Atomic's Avatar
I have a gauge for that
What I mean is if you are seeing a -25% afr error (25% too rich) across the board, increase the IFR table by that same amount. Computer thinks injectors are bigger, so opens them for a shorter time.
Old Jul 28, 2012 | 08:02 AM
  #236
This has to come from a known good source, mainly the company that makes the injectors or anyone who has flowed them to find the offsets and min pulse etc. Myself, I wont get injectors unless I know I can get good info on them. If I go any bigger i will just go low impedance. Getting High impedance injectors to pulse low enough at idle always proves to be a bitch from what I have seen.
Old Jul 28, 2012 | 10:14 AM
  #237
smokeshow's Avatar
Lol I was joking.
Old Jul 28, 2012 | 12:57 PM
  #238
Gadgetized's Avatar
There is something wrong here. Be patient, and figure it out before you damage something. I would not want to get E85 in the oil due to over fueling.
If you have a good known injector with accurate values, even if they are the original ones, I would put them in. I would then get it running properly with those injectors and good values. As Atomic said before, your VE table should not change when switching injectors. If your VE is off, the injector values are off.
Have your injectors been flowed? Do you know your fuel pressure is correct?
I had problems with my injectors, and eventually figured them out. I had a well known tuner stumped on them, and he could not get my truck running for crap. The problem with large injectors are, they open too big, and the problem with small injectors are they open too small.
Old Jul 28, 2012 | 01:50 PM
  #239
Just spent a half hour on the phone with Jon, I'm getting somewhere!
Old Jul 28, 2012 | 04:48 PM
  #240
scooter k's Avatar
I've got the injector data on the 2000's
