2007 "Escalade V" LSA Swap.
Old Feb 3, 2016 | 10:51 AM
2 SSlow's Avatar
Default 2007 "Escalade V" LSA Swap.
I picked up a 2007 Escalade back in October 2015. I am working on making it the way that it should have been offered from the factory. 6.2 with a 6L80 is already a pretty strong running setup in these trucks, but they need more...
LSA blower
LS9 Cam
LS9 Valve Springs
ZL1 blower lid
CTS-V fuel injectors
ZR1 fuel rails
CTS-V heat exchanger
CTS-V heat exchanger pump
LS7 Throttle Body
LS7 MAF
Ported blower snout/matched to case
Edelbrock Fuel Pump (since mine isn't Flex Fuel)
LSSimple Accessory Drive (to get the LSA to work with the stock truck accessories)
Pinned Crank
Custom 4" Cold Air Intake
20% window tint, 35% windshield tint
2" drop spindles, 3" Eibach lowering springs
ETC....
I'm going to run the stock 2.95" pulley with the stock truck balancer...so 6.5psi.
I am still gathering parts, but I hope to have it together and running sometime in the Spring. With the 10.5:1 compression of the L92, that should be enough to get started.
Old Feb 3, 2016 | 01:25 PM
travieso's Avatar
sub' should be a stout setup when all said and done..
Old Feb 12, 2016 | 07:15 AM
2 SSlow's Avatar
OK....so my Escalade doesn't have a FPCM. Apparently that wasn't implemented until late 07-08. My build date is 12/06....and it's not there. WTF.
Old Mar 17, 2016 | 07:56 PM
Slow91z's Avatar
Excuse my ignorance, but what's a FPCM?
I'm sure I could search it out, but I'd also like to see this thread pushed to the top for a update, lol
Old Mar 19, 2016 | 07:15 PM
Petraszewsky's Avatar
Fuel pump control module
Old Mar 20, 2016 | 10:50 PM
How are you guys attaching the factory fuel line to the LSA fuel line? The braided line coming off the factory hardline looks like it is crimped on. Can that be cut off and a quick connect put on or what?
Old Apr 15, 2016 | 10:21 AM
2 SSlow's Avatar
My uncle got his done already, I have too many projects to dump money in this one right now. Runs good from what I hear, 7psi with stock exhaust and pulley setup. Very clean install. I will try to post pics later.
Old Jul 1, 2016 | 10:57 AM
2 SSlow's Avatar
Just wanted to update that nothing has been done...LOL. Trans slips in 5th gear, so reman trans will have to happen first. I bought a 2016 Seadoo RXP-X300 that I have put all of mod money in to for the time being, oops.
Old Feb 12, 2020 | 07:38 PM
...4 years later
How's the Caddy doing?
Slightly off topic. I have 2" spindles front and 3" springs/shock relocation brackets rear. I kept auto level shocks on the rear and bent the adjustment rod precisely according to the directions. I'm afraid however the rear is still being held up by the auto level shocks. Did you retain auto level shocks?
skolman91
Nov 18, 2019 07:19 AM
jmgak47
Oct 8, 2017 08:29 PM
JR 427
Dec 1, 2015 07:31 AM
tylerj
Aug 3, 2014 02:58 PM
parish8
31
Mar 21, 2007 08:24 AM
