2001 Frame up build
Old Mar 11, 2008 | 01:22 AM
  #301
chevyguy7802's Avatar
Nice work man!
Old Mar 11, 2008 | 08:16 AM
  #302
I hope to have some mandrel bent frame rails ordered today
Old Mar 11, 2008 | 11:47 AM
  #303
Yogi Bear's Avatar
Nice work on the jig! Good luck with the new frame!
Old Mar 11, 2008 | 12:00 PM
  #304
CJ Hungus's Avatar
You are a metal working maniac!! If I even attempted to fab up the frame table my head would
Old Mar 11, 2008 | 12:13 PM
  #305
350SS's Avatar
I love fabrication threads. I couldn't even afford the gas and wire for your project so I'm going to have to live vicariously through you man. This is great Keep it up!
Old Mar 11, 2008 | 12:26 PM
  #306
thanks guys, can someone change my thread title and just add (NEW FRAME?! pg8) at the end thanks!
Old Mar 27, 2008 | 03:18 PM
  #307
worked on it this past weekend.
used my old rotors for a jig to set the hubs at ride height
Now this right here is why I'm running the new frame, at ride height I want my control arms to be on a better path than this,
So I took some measurements and found the angles, took the arms off since the frame will be coming off the table soon
and I went over to the drawing board, or my plywood and maybe a full scale model of how the controls arms are setup
Above is how they are currently setup, 14* on the lca and 33* on the upper, YIKES :insane: The left is the spindle and the right are the pivot points on the frame.
I will leave the spindle side alone, which means it will look like this
which is what stock arms are setup at, lca 0* and upper 10* (I believe)
So the control arms have to be raised a little over 2" both lower and upper, and I plan to flip the tierod also, and I will make sure to set it up so the tierod is on the same plane as the lower so say if when I flip it, it changes the height 2.25" and the arms need to go up 2.5" I will sacrifice that .25" and raise them only 2.25"
This represents it fully laid out, with 9* negative camber
here is a video explaining what I just explained above
Old Mar 27, 2008 | 03:38 PM
  #308
1FastBrick's Avatar
Custm2500's Rude Friend
Damn... If only I knew you were going to mock up the suspension in that fasion, I could have made you some plates that you could have bolted on to the rotor or even the spindle for that mater. I could have used some of them fancy crossdrilled and slotted rotors...
Old Mar 27, 2008 | 04:09 PM
  #309
BlackGMC's Avatar
Resident Retard
I thought you were getting a tube chasis?
Old Mar 27, 2008 | 04:16 PM
  #310
8ALTNG's Avatar
damb man. you have got your **** figured out. this is definitively going to be a slick setup
