1993 Chevy C1500 RCSB - 5.3L/4L60E - Then 'till Now.
Old Aug 28, 2024 | 07:33 PM
  #51
strutaeng's Avatar
5 Year Member
Originally Posted by wmpotter399
I have a question for you. I came here looking to find out if I can use my existing 1993 4L60E transmission behind a 6.0 YL6. The title on your post says you are using a 4L60E. But your spreadsheet says that you used a 4L80E. Did I read wrong? Can the 93 4L60E be used?
No, you cannot use the 93 transmission on the LS. Look here: https://ls1tech.com/forums/automatic...nge-100-a.html
Looks like 1993 4L60e was a 1-year only model.
Just get yourself any newer model 4L60e with the LS top bellhousing bolt hole. Any full sized truck or SUV GMT800 will work.
Old Aug 28, 2024 | 07:55 PM
  #52
wmpotter399's Avatar
Registered User
I guess I wasn't specific enough. I am going to use an Ace's computer and harness. They say that it will work the transmission. I was just curious about bolting up. Are spacers required? What flexplate? What converter?
Old Aug 29, 2024 | 12:00 PM
  #53
strutaeng's Avatar
5 Year Member
Oh, ok. I understand.
You need some special flex plate for sure. Looks like Speedway Motors has one, part #91604000 and it's $155. I think others make different ones but they do the same. I thought they were more expensive. I don't on the TC.
Here's the source that talks about the torque converter bolt pattern: https://www.speedwaymotors.com/the-t...NrjoAUf_oBQPeW
My concern is your 1993 transmission is not going to last with an LS in front of it. The earlier 4L60e models had a ton of issues and the internal hard parts were very weak, especially if they came with a V6. The later transmissions were improved for the LS powerplants and had better hydraulics.
Unless you are a transmission rebuilder and can upgrade all of the weak internals? IDK.
Old Aug 29, 2024 | 12:31 PM
  #54
Registered User
Here's the source that talks about the torque converter bolt pattern:[ I will post this later]
The LY6 is a Gen 4. The flexplate that you sent says it is for a Gen 3. Will it work?
Old Aug 29, 2024 | 01:11 PM
  #55
strutaeng's Avatar
5 Year Member
Yes. There is no difference on the bellhousing/crank flange between the Gen III and Gen IV, but confirm your engine has the 6 bolt flange.
Also, I edited my response above.
oakley6575
Aug 28, 2015 04:02 PM
darnie
Feb 11, 2015 11:36 PM
91ls1silverado
Sep 16, 2014 08:09 PM
AUTOT3K
Jul 12, 2014 12:36 AM
