1991 Silverado frame off rebuild-LS powered
Old Aug 24, 2012 | 02:38 AM
  #21
Low91's Avatar
Well I haven't been keeping this up to date but haven't really made much progress. Got the fenders primered and hung, got the PCM tuned, put in the dash and column, had the spacers made for the front so the wheels aren't sucked in and now I can snap in the center caps. Also started the truck but there was a bad vacuum leak and a few bad connections in the harness that I'm tracking down now.
Here's a shot of the spacers and longer studs as well as the one ton calipers.
As you can see the hub no longer protrudes through the wheel.
I'm pretty happy with how it sits. Should be a bit lower once the springs get broke in.
Old Sep 7, 2012 | 01:40 AM
  #22
Low91's Avatar
I've just been working on getting it started, reworking the go pedal, and bolting up some underhood items. Here's a few random pics I took.
The Novac A/C bracket and new compressor, the compressor is in a slightly different location so I still have to have custom lines made.
Routing of the steam pipe/coolant crossover or whatever you want to call it. I didn't want to tap the pump at first but it looks cleaner than another hose running to the radiator.
Intake and wiring on. The intake is only temporary, I plan to build a filter box on the passenger side where the battery use to be.
thunder550
Oct 8, 2015 04:53 PM
Oobray
Aug 12, 2015 10:56 AM
carid
Jul 24, 2015 05:00 AM
Ketis
Jul 23, 2015 12:37 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
