1990 c1500 s480 ladder bar cage and more
Old Oct 5, 2014 | 08:40 PM
tempoffroad's Avatar
Default 1990 c1500 s480 ladder bar cage and more
I would like to start off and say thanks for all the help I have received on here. I should have started this about a year ago and just have not had the time. This truck was originally a long bed and I found a frame and just swapped it all over to a short bed about a year ago. I then swapped over the lq4 into a truck that my grandfather passed down to me. I installed a 4l80e and a cam. I dynod the truck to around 380 at the wheels. this with a 3200 converter from circle d. I think I ran an mid 8's with this. Then 6 months later I installed an on3 turbo and ran mid 7's. well not happy with that I went and installed the Holley hi ram all new fuel system. I am using a holley dominator pump with all an lines and fic injectors and the s480 from force inductions. I pulled out the stock computer and installed the holley dominator. I have now started to run in the high 6's at 106. The new goal for the truck is to loose some weight add some traction and run high 5's. I don't really have a budget within reason. I have placed an order for a lot of parts and still need to add more. I will try and post as often as I can. The new parts on order is a turbo 400 with tbrake from Rossler. a full front drag brake set up from aerospace to help shed some weight and now run 4 3/4 bolt pattern. Parts still needed is ladder bar rear as well as brakes and new shafts. I am going to order weld wheels for all corners. I have been working on the cage as well. It is getting a full 12 point cage.
Attached Thumbnails 1990 c1500 s480 ladder bar cage and more-dscn0316.jpg   1990 c1500 s480 ladder bar cage and more-dscn0317.jpg   1990 c1500 s480 ladder bar cage and more-dscn0319.jpg   1990 c1500 s480 ladder bar cage and more-dscn0321.jpg   1990 c1500 s480 ladder bar cage and more-dscn0318.jpg
Old Oct 5, 2014 | 08:44 PM
a few more pics
Attached Thumbnails 1990 c1500 s480 ladder bar cage and more-dscn0322.jpg   1990 c1500 s480 ladder bar cage and more-dscn0323.jpg
Old Oct 5, 2014 | 11:23 PM
sammygroundzero's Avatar
Looking good nice work
Old Oct 6, 2014 | 09:59 AM
BigBlock90's Avatar
that thing is already rolling with running high 6's.... cant wait to see where it ends up!!
Jamie
Old Oct 6, 2014 | 05:30 PM
a few more pictures, my camera died last night
Attached Thumbnails 1990 c1500 s480 ladder bar cage and more-dscn0325.jpg   1990 c1500 s480 ladder bar cage and more-dscn0327.jpg   1990 c1500 s480 ladder bar cage and more-dscn0328.jpg   1990 c1500 s480 ladder bar cage and more-dscn0329.jpg
Old Oct 7, 2014 | 02:59 PM
thunderwagen's Avatar
Those are some pretty good times man I look forward to seeing where this thing goes.
Old Oct 7, 2014 | 03:52 PM
ecir45's Avatar
Is the 9" a stock width?
Old Oct 7, 2014 | 06:17 PM
Yes. Its stock width from an 1980 f100. It fit just fine. I am getting 15x10 weld wheels for rear and will order new shafts for a 4 3/4 bolt pattern but will keep width the same. Just will get a little more back space wheel.
Old Oct 7, 2014 | 08:42 PM
ecir45's Avatar
Cool, I think those are 65.25 WMS. I was considering one but decided to go with the 14 bolt for now.
Old Oct 7, 2014 | 08:51 PM
project 67 sub's Avatar
5x4.75" bolt pattern? full size gm 1/2ton 2wd trucks from 1971 to 1998(99) are 5x5" bolt pattern just to let you know
