1990 408/4l80e/s480 turbo build
Old May 25, 2012 | 11:05 AM
  #21
1994Vmax's Avatar
2 wheel drive 6 lug light duty ( 7200 lb GVW) 2500 rear diffs are probably way easier to find and are cheaper for sure. Just redrill your axles for 5 lug as aftermarket or OEM 5 lug 9.5" 14 bolt shafts are not available.
Old May 25, 2012 | 12:37 PM
  #22
06-crewhauler's Avatar
I am going to use a tbss 14 bolt in mine 96 already narrow for wider tires
Old May 25, 2012 | 01:08 PM
  #23
vicalma03's Avatar
I think im just gonna stick with the 10 bolt and tru-trac till it breaks. Ill call you tomorrow Kyle! I want to see the extra150 hp!! Ha the white beast!!!!
Old May 25, 2012 | 06:39 PM
  #24
JankesGTO's Avatar
I think you will be ok with the tru trac. Where is yall goin thats got a dyno?
Old May 25, 2012 | 08:21 PM
  #25
vicalma03's Avatar
theres gonna be a HPD meet at LMR on Sat. Think it starts at 9pm. You want to come out??
Old May 25, 2012 | 08:27 PM
  #26
vicalma03's Avatar
Truck is now at my house and motor is in!!! Well..... Actually its in but not bolted to the mounts. I couldnt get it to align correctly. I think I may have the brackets on worng.
Old May 25, 2012 | 08:43 PM
  #27
vicalma03's Avatar
Yup!! Just looked at the ebay ad and I have the plates on wrong!!Easy fix!!
Old May 29, 2012 | 03:13 PM
  #28
thunderwagen's Avatar
If you will cut out or flatten the raised up section in the middle of the cups they will fit better onto the adapter plates.
Old May 29, 2012 | 09:51 PM
  #29
vicalma03's Avatar
Thats exactly what I needed to do. Everything lined up great. I picked up a circle d triple disk from Kyle and now just need to install the shift kit so I can mount the trans. Looks like this project is gonna start picking up speed! I want to complete it by the end of June!! Name:  IMG_20120527_110056.jpg
Old Jun 2, 2012 | 03:58 PM
  #30
vicalma03's Avatar
Motor and tranny are in!! Now gonna start on the front and rear suspension. I'm thinking of 2/4 drop or maybe a 4/6. Not sure though. I'm doing 255-60-15 up front and 275-60-15 nitto's out back. Heres some pics to keep the thread going.
