1989 Toyota 4Runner
Old Dec 9, 2023 | 01:24 PM
  #61
shakenfake's Avatar
Shlumpt
5 Year Member
You are staying with the original wheels?
Old Dec 9, 2023 | 01:38 PM
  #62
Bgbldodge's Avatar
It’s got some aftermarket fake bead locks on it. I’d like to find some original wheels to put on it but these are fine.
Think I found a shop to repair the radiator. Going to try to get it titled this week.
Old Dec 10, 2023 | 12:58 PM
  #63
Bgbldodge's Avatar
Took the tires off to clean the wheels of snail shells and mud. Decided to inspect the front brakes. Passenger front only has 1 of 4 pistons moving. Driver front is fine. I hadn’t gotten around to adjusting rear drums so I checked those. Shoes weren’t even close to touching. Got those tightened up a bit. Maybe my parking brake will work now.
I’m waffling on backing them off another couple of clicks. I can rotate by hand from just the lug but it does take some effort.
Blinker module and new front and rear wipers ordered.
Old Dec 13, 2023 | 03:10 PM
  #64
Bgbldodge's Avatar
Calipers, pads, rotors, radiator, thermostat, and radiator cap ordered.
I called a couple of places and it would cost me more to have the brass tank fixed than to just buy a new one. $200 to clean and pressure test and solder a pin hole. If it's the tanks, they wouldn't even quote me a price. Not worth the hassle.
Old Dec 15, 2023 | 04:17 PM
  #65
Bgbldodge's Avatar
New. Not reman.
Old Dec 15, 2023 | 05:38 PM
  #66
wretched73's Avatar
Nice score on the new calipers. The past few remans I've received have been dog ****.
Old Dec 15, 2023 | 06:58 PM
  #67
Bgbldodge's Avatar
$35 each on Rockauto. Remand were like $25 plus core. Not worth it.
Old Dec 20, 2023 | 05:09 PM
  #68
Bgbldodge's Avatar
Gigantic 54mm socket for these tiny hubs. My one tons on my blazer are half that size. Any bets on this being 1989 OE grease?
Old Dec 26, 2023 | 03:54 PM
  #69
Bgbldodge's Avatar
Well I went to finish the one side up and like everything else today, it fought and eventually won. First, the calipers I got were for the later model year and not the previous model year. No biggie, trim the dust shield and done. Then the pads I got were for the previous model year and not the later model year so they are to short. So gotta get more of those.
Old Jan 7, 2024 | 11:28 AM
  #70
Bgbldodge's Avatar
Brakes bled. New radiator, thermostat, temp sensor, and cap installed. Had to do a bit of trimming on the fan shroud and gotta pick up long bolts for the fan shroud to bolt to the radiator but otherwise it fit pretty well. Pretty certain everything was OE from 1989 except the coolant. It was actually really clean and clear and zero sediment so I’m assuming it got flushed at some point.
