04 ext 4x4
Old Sep 4, 2017 | 04:32 PM
  #21
5speedsilverado's Avatar
Originally Posted by M60gov20
Looking good!
Originally Posted by AbelKcco
hell yes i dig this thing! jealous of how clean your trucks are out there without the rocker rot we have to deal with here... i'm in for updates!
thanks guys, yeah its great out here, hardly ever any rust in the native Arizonan vehicles. this one was a survey truck for new housing developments and spent most of the time in dirt and only rust was the small spot in the passenger side floor board which was probably from a popped heater core considering it had been bypassed when i picked the truck up originally
Old Sep 10, 2017 | 08:36 PM
  #22
not much progress this weekend, but got the ac box rebuilt. id say the evaporator was clogged
factory sound deadoner piece cleaned up the past it could be and ac box bolted back up with new heater core, all 4 new actuators, and evaporator. this stuff is so stained from dirt it will not clean up.
got one of the extended cab door panels cleaned up, installed a new speaker and ran new speaker wires ran to them
Old Sep 24, 2017 | 07:49 PM
  #23
add a leaf for the rear suspension
finished up coating the rear section of the frame
rear lift blocks installed and suspension bolted together so itll still roll out for the other paint work
bed painted tailgate painted
Old Oct 1, 2017 | 06:25 PM
  #24
main support for the dash installed
starting to wire in the power door locks and windows
fully wired and tested with an external power supply. wires all out of the way of the window and new speaker installed in the door
dont think the aftermarket switches look too bad.
bed fully sanded, and sprayed in primer before getting bedlined
bed fully lined.
tailgate lined
Old Oct 1, 2017 | 06:48 PM
  #25
dropped the engine off at the machine shop, checked out good, crank is getting a very light .010 grind, and getting bored to ls1 specs, should have it back very shortly. its getting some 243's flat top pistions and a very small trick flow cam
Old Oct 1, 2017 | 08:27 PM
  #26
1FastBrick's Avatar
Custm2500's Rude Friend
What did you use for a spray in bedliner product?
Old Oct 2, 2017 | 10:32 AM
  #27
BudRacing's Avatar
Wow, you don't see many frame off restorations on ten year old trucks. This is cool. Great work so far.
Old Oct 8, 2017 | 08:25 PM
  #28
not much progress this weekend, but the bed is on
Old Oct 8, 2017 | 08:28 PM
  #29
it was called buckshot bedliner, something a local paint supply store recommended
thank you, means alot, its not perfect, but itll be nice for a 236k mile truck
Old Oct 14, 2017 | 07:18 PM
  #30
Cameronswmp9's Avatar
Work looks good! I like the color!
For the doors, would it be easier to get power doors, or does this harness not have plugs for switches? Asking completely out of curiosity, obviously too late for this project.
