'03 Z71 Tahoe - ByeBye 11mpg.. Hello 4BTA Cummins
#85
Total of 50 gallons?
How you plan on doin the pickups? Let the rear pump to the main tank and let it just pull fuel like it currently is working right now?
My brothes old work truck was RCLB 3500 with a work bed, but it had a rear and front tank. The rear tank pumped to the front tank a little at a time i guess to keep the same amount in each tank.
#86
#88
Mechanical lift pump that is engine driven... kinda like an old school small block Chevy pump...
Anyways... I'm running 2 high volume switch valves from greasecar... only ones I could find that would hold up to heated oil... I'll run one for the feed and one for the return to keep tanks from blending...
I've got the switching valves... just need the tank and plumbing.
-Chris
-Chris
#89
Hey guys...
Been daily driving the truck all month and the trans seems to be doing good other then the slight delayed reverse.
Waiting on fundage to get the next stage of the build going... hopefully the 2nd fuel system and the HX35 turbo will be at least started on next month... 20psi feels pretty good... cant wait to see what 40+ does. From research, it should put me in the ballpark of 500+ ft. lbs to the pavement with supporting mods. Gonna have to find a way to stuff an air-air intercooler in it soon.
Well.. that's all I got for now. Not much of an update... but waiting on money always sucks.
-Chris
-Chris
