'03 Z71 Tahoe - ByeBye 11mpg.. Hello 4BTA Cummins
17 Attachment(s)
Hey alls...
Been lurking around here for a little while... figured I should post a build thread... I've got a 2003 Z71 Tahoe... rolled 100k miles just before I pulled the motor... got tired of not being able to afford to drive the thing. Anyways... Here it is when I brought it home from the stealership... Attachment 117412 And a few months later... Attachment 117413 Then while the 4wheel jamboree nationals in Indianapolis, I saw a Jeep scrambler with a 4bt Cummins swap... turning 40's and doing it quite well.. I figured why not. After some convincing with the wife, I started to cut up the truck I was still making payments on :devil: Making room for this... Attachment 117413 Out with the old... Attachment 117415 Attachment 117416 Going in for motor mount mock-up... note the Destroked adapter and flexplate Attachment 117417 Back in the garage for some touch up.. Attachment 117418 Motor mounts... Attachment 117419 Attachment 117420 Attachment 117421 Back in the truck getting plumbed.. using hydroboost brakes from an '05, plumbed using stock lines from the '05.. fit was perfect. Also check out the heater hoses and what have you... it was like it was meant to be.. Attachment 117422 Attachment 117423 http://img.photobucket.com/albums/v7...p/P1010538.jpg First start in the truck... craptastic phone camera... http://img.photobucket.com/albums/v7...h_MVI_0103.jpg Then came the wiring... Attachment 117424 Attachment 117425 Attachment 117426 Attachment 117427 Attachment 117428 |
11 Attachment(s)
Fuel pump delete...
Attachment 117401 Attachment 117402 Bauman trans controller Attachment 117403 Installed.. Attachment 117404 '05 e-fans installed.. Attachment 117405 Exhaust... 3" downpipe to 4" downpipe back using 4" banks monster muffler Attachment 117406 Attachment 117407 Attachment 117408 And finally on the road... had a friend cut some decals for the truck... Attachment 117409 Attachment 117410 Attachment 117411 And this is a first drive video... this was taken before the exhaust was done... so its open downpipe... just down the block. 2003 Z71 Tahoe - 4bta Cummins Swap - YouTube Quite a bit has gone on since then... I've killed 2 4l60e trannies... and am currently working on over building an 80e for it with parts from Jakes and a billet low stall converter from Hughes... I also have another turbo on the way and will be setting up a mid sized compound system come early summer... shooting for 550-600 lb. ft. to the ground. So far.. worst tank of fuel got around 15mpg which is still an improvement over stock.. shooting for low 20s when its all said and done... and I wont be running on straight diesel :) I gotta go to work... more details to come -Chris |
pretty cool swap. keep us updated.
You did a great job on the swap!
Diesel is a great choice, even my ol' 6.2L NA Diesel in my 83 Jimmy got 16MPG, with a 4" lift and 35" mud tires. Slow as balls though, but still very useful. |
Awesome build! Looks like some good work to.
very cool swap! but for some reason the amount you spent on doing this and all of the new transmissions you have gone threw and will go threw probably will equal allot more then what you would have paid in gas for the life of the vehicle as a gas motor lol , buy very cool as i said .
Lol... well.. it depends on how you look at it.
Soon... I'll be driving for nearly free... and so far including the tranny build... I've got less then 7k in the swap. If I spent 10k on it... I will make that back in 30k miles with just fuel savings... running W80 ftw! More on that later :) |
Gotta be the coolest/differentest (if thats a word) swap.
goin out on a limb here, but were you able to get the tach to work? |
This is cool as hell. Good work sir
This is badass. What turbo is that?
