03 SS awd turbo street build
Old Apr 28, 2018 | 10:11 PM
  #181
SDjeff619's Avatar
Thanks fellas, and shout out to Richard, Atomic for getting this start up tune dialed in. I’m itching to break this motor in and see how this thing feel so with boost.
Old May 11, 2018 | 08:38 PM
  #182
SDjeff619's Avatar
Update:
Been having some issues with tuning the Hughes 4l80 swap trans but on a positive note, I finally finished the mounting of the AFR500 wideband, boost, fuel pressure, ethanol % content and 2 step toggle switch.
Old May 14, 2018 | 03:52 PM
  #183
BudRacing's Avatar
Very nice! Is that center gauge fuel pressure measured in bar?
Old May 15, 2018 | 08:41 AM
  #184
SDjeff619's Avatar
Thanks Bud, no the fuel pressure is psi. The trucks off just in accessory. Both 450 pumps don’t seem to hold line pressure once the truck is shut down. I thought the Wally’s had check valves to prevent this.
Old May 15, 2018 | 09:33 AM
  #185
Atomic's Avatar
I have a gauge for that
Mine hold pressure pretty well...sure you dont have a leak somewhere? Likely inside the fuel bucket.
Old May 15, 2018 | 11:10 AM
  #186
moregrip's Avatar
what a rush!
Originally Posted by SDjeff619
Got a cheap $10 set of wheel center caps and SS vinyl decals for the Cosmis wheels. I prefer a flush center cap over a giant plastic button sticking out of the center.
I also got everything in the engine compartment done. It was a little nerve racking for the initial startup with a new motor, trans, turbo, entire e85 fuel system so on and so on. Atomic supplied the start up tune but engine shuts down after 30 seconds going into REP mode with a handful of codes.
Very nice job!
Old May 15, 2018 | 02:20 PM
  #187
03sierraslt's Avatar
Most aftermarket FPR’s say right in the instructions they are not designed to hold pressure with the pump off. Mine included.
As long as it fires right up normal it’s a non issue.
Old May 15, 2018 | 06:15 PM
  #188
SDjeff619's Avatar
Yeah, my Aeromotive X1 says the same thing in the manual. It does fire right up when turning the ignition from off to start. But if I turn to accessory and wait a bit before turning it over, it takes a few seconds before firing up.
Old Jul 17, 2018 | 05:49 PM
  #189
Is that a 2014 and up overflow tank? Do you have anymore pictures of how it’s mounted? That looks nice and clean
Old Jul 18, 2018 | 12:42 AM
  #190
AkSSS's Avatar
I haven't been on here for a while. This thing look AWESOME!
I gotta know. How is it running?
