03 Sonoma 5.3L swap project
Registered User
Registered User
Got to test fit the motor last night. awesome fitment with no rubbing or touching!
Also got notification that my Circle D 278mm 3200 stall TC was shipped!
Registered User
Got my Circle D TC and trans mounted. Shoved everything into the Slonoma. Had to lift the front half of the cab up to make rooms but she’s in and all torqued down.
The two are now one!
Definitely the exact opposite of throwing a hotdog down a hallway!
Good clearance
Hoping the front springs start settling a little more otherwise the 3” drop in the back is going to look goofy lol
Good clearance
RoccoVNVLVMC (05-01-2018)
Registered User
Some more updates. Got my hands on an 8.5” rear end with disc brakes! Unfortunately had open diff so getting an Eaton Posi-Trac and 3.73 ring and pinion. Did coil relocation. Ordered radiator, dual fans, new rear suspension minus leafs since I already have the ZQ8 setup. 3” blocks for the rear.
Boooo... open diff with 3.42 gears...
Coil relocation. Will play with the harnesses when the wiring fun begins.
Ready for the new goodies!
Registered User
Got the box off and found 15 years of lovely Texas caliche...
All washed up
The old 7.5" out!!
Coated the frame
Got my 3.73 gears in... Just waiting on my posi diff so I can complete rear end. Swapped over the leafs and installed lowering kit and new shock absorbers. Then its putting an *** back in the Slonoma!
All washed up
The old 7.5" out!!
Coated the frame
This should be pretty nice when finished. I've always had a soft spot for S-series trucks after owning a 2dr Blazer for 8 years. Lots of aftermarket, inexpensive parts, compatibility across multiple platforms... lots to love.
FYI, While you've got it torn apart, you may want to look into the Blazer brake swap.
RoccoVNVLVMC (05-16-2018)
Registered User
