Zex window switch
Old May 2, 2009 | 08:55 PM
08tundra's Avatar
Default Zex window switch
Ok I spent the day installing my Zex kit on my Tundra and when I got to the window switch I can not figure out how to program it, I didnt go through alot of different settings but the way I thought it should be set didnt work. Anyone have any experience with these window switches? http://www.zex.com/Base/Instructions/ZEX169.pdf Here is a pdf of the instructions I cant get step 1 figured out for the tach signal.
Old May 2, 2009 | 09:09 PM
RandomHero's Avatar
You have to find out which wire is your tach signal. For me it was a white wire behind the gauge cluster. Being that you have a tundra I have no idea what it would be. Aside from finding a wiring schematic, I'm not sure how else you could test for a tach signal.
Old May 2, 2009 | 09:12 PM
08tundra's Avatar
I have the tach signal wire, its the blue/yellow wire from my first coil pack left side its the actual programming of the switch I cant figure out.
Old May 2, 2009 | 09:20 PM
RandomHero's Avatar
What do you mean. I have mine set to 3000 rpm activate and 6200 deactivate. The zex window switch may be different, but it was not hard at all to do my MSD window switch.
Old May 2, 2009 | 09:32 PM
08tundra's Avatar
maybe I am not reading the instructions right but on the pdf I posted its the stuff in step 1 for the initial settings, this is all on the bottom of page three of the pdf.
Old May 2, 2009 | 09:55 PM
1989k1500's Avatar
Those directions are kind of a cluster ****. lol
I dont know if you are supposed to have the numbers at 00 because you are only getting signal from one coil or if you are supposed to be at 08 for 8 cylinders.
Old May 2, 2009 | 09:56 PM
1989k1500's Avatar
0 0 = individual coil per cylinder systems where the TACH wire is connected to the coil
0 1 = coil packs that fire in pairs (waste spark systems) and the TACH wire is connected to the coil
0 2 ~ 1 2 = number of engine cylinders, from 2 to 12, where the TACH wire is connected to the tach
from the engine electronic controller or distributor
Sounds like you need to set it to 00, because its an individual coil per cylinder.
Old May 3, 2009 | 03:08 PM
TrickTurbo's Avatar
Truck Sponsor
00 if you are on 1 coil per cylinder. And you are connected at the coil...
Texas5.3_1251
Mar 5, 2016 08:10 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
Closer_2001
Sep 24, 2015 09:15 PM
