Wow!! Efi Direct Port Super Easy!!
Old Oct 4, 2005 | 05:50 PM
NitrousDirect's Avatar
Well they sit about 1/2 inch higher due to the nozzle
Re your radix setup do you have some sort of different injector setup?
Old Oct 5, 2005 | 06:34 PM
KySilverado's Avatar
No, not really different. It does use OEM 43lb injectors. Went out and had another look at things, It uses aluminum fuel rails that, with spacers, might do the extra half inch lift. Probably have to re-route the intercooler cooling lines, might hit the power valve on the drivers side? If the bases worked, none of the pre-bent tubing would I think. Maybe on the drivers side but you would defiantly have to get creative with the tube bending to get it all plumbed on the passenger side.
Old Oct 5, 2005 | 07:58 PM
GoldenVelvet's Avatar
That is so nice its almost pornographic
Old Oct 5, 2005 | 08:18 PM
Well as for our tubing if that's what you were talking about the base kit comes with poly line you size yourself, or we can do a braided line kit. I'm willing to bet you can make it work, and with less than you think
Old Jul 3, 2006 | 11:20 PM
dirt track racer 81's Avatar
i know this is pretty old thread but i was wondering if any truck guys have tryed this route yet??
Old Jul 30, 2006 | 12:00 PM
Ross @ EDO's Avatar
FormerVendor
Im wondering this also, I was considering going to a 2 stage dual nozzle setup, but the more and more I think about it I want to go direct port
Old Jul 30, 2006 | 02:24 PM
Grumpy5.3's Avatar
would this setup be safer or more dangerous with the fact that cyl #7 is the first one to go lean???? it looks like an awsome setup, and I have never had nitrous on a LSx engine, but am leaning that way. Just curious...
Brian
silverstreak07
Jun 28, 2016 06:29 PM
Silveradorst07
Dec 31, 2015 12:04 AM
spiritfish
Aug 23, 2015 09:58 PM
rojeho
Jul 12, 2015 06:10 PM
