Wiring help on 2012 6.2
Old Dec 14, 2012 | 03:43 PM
CodyG's Avatar
Default Wiring help on 2012 6.2
I have a 2012 6.2 and want to wire up my window switch, what wires do I need to tap? Ive got a MSD 8969 and the WOT will be on a button. Thanks.
Old Dec 14, 2012 | 03:53 PM
nonnieselman's Avatar
So you wanna use your window switchs for the nitrous arming??
kinda unclear of what your doing.
Old Dec 14, 2012 | 03:54 PM
your window switchs are also momentary so remember that.
Old Dec 14, 2012 | 04:11 PM
Can use a couple of these....
DEI 611T Mosfet Multiswitch NEW
Old Dec 14, 2012 | 04:12 PM
Tap them into your Window Up side of the switch.. Done.
NO have to rewire anything, just tap into the wire at the motor.
put a couple LEDs on the das so you know when the signal has been sent and when your window switch has powered up.
Put a master switch under the dash so it cant be activated inadvertantly..
Old Dec 14, 2012 | 04:15 PM
CodyG's Avatar
That MSD window switch dosent have a built in TPS, and I dont want to fab a WOT micro switch so Ill use a push button to act as the WOT micro switch. I need to know what color the tach wire is and where mainly.
Old Dec 14, 2012 | 04:29 PM
hum.. i know on the 99-02 is the white wire..
might have to do a lil reading or call MSD.. i believe you can tap one of the wires on a coil.. cant rem which tho.
Skip Fix
22
Jul 9, 2016 07:08 PM
Jonblarc7
40
Dec 23, 2015 10:15 PM
Silver8ado
Sep 30, 2015 11:42 AM
Silver8ado
Sep 14, 2015 06:35 PM
rednekferlife101
Sep 14, 2015 05:27 PM
