Wiring help on 2012 6.2
Tap them into your Window Up side of the switch.. Done.
NO have to rewire anything, just tap into the wire at the motor.
put a couple LEDs on the das so you know when the signal has been sent and when your window switch has powered up.
Put a master switch under the dash so it cant be activated inadvertantly..
That MSD window switch dosent have a built in TPS, and I dont want to fab a WOT micro switch so Ill use a push button to act as the WOT micro switch. I need to know what color the tach wire is and where mainly.
Skip Fix
22
Jul 9, 2016 07:08 PM
Jonblarc7
40
Dec 23, 2015 10:15 PM
rednekferlife101
Sep 14, 2015 05:27 PM
