what would meet its max first?
Old Feb 22, 2007 | 01:35 PM
sharpshooter's Avatar
Default what would meet its max first?
Would the injectors or the fuel pump on a 1999 5.3 meet there max first[make it run lean] running a large dry shot?
Old Feb 22, 2007 | 01:37 PM
silver-mod-o's Avatar
Hunt&Fisherator
probably the pump, followed closely by the injectors. put in a 255 pump and run a wet shot IMO... much safer and easier to tune.
Old Feb 24, 2007 | 12:54 AM
99Silverado5.3's Avatar
Injectors will. Get 255 intank fuel pump and injectors and then your motor will go before you run out of fuel.
Old Feb 24, 2007 | 01:01 AM
RandomHero's Avatar
Yup our 99's had tiny *** injectors(19lbs). I have some 31# injectors for sale in the classifieds....
Old Feb 26, 2007 | 07:15 AM
Default Injector ?
How do you know what size injectors to buy and where is a good place to get them?
Old Feb 26, 2007 | 09:15 AM
slowprocess's Avatar
My injectors maxed first. You can get a set of stock 8.1L injectors for $100 or less, just look around. They will be more than enough for your setup. You will have to get tuned for an injector upgrade.
Also, +1 on the 255 fuel pump swap.
Old Feb 26, 2007 | 11:39 AM
How much of a dry shot would you think it would take to max out the injectors or fuel pump?[1999 5.3]
Old Feb 26, 2007 | 11:59 AM
RandomHero's Avatar
50 ish, I'm maxed out on them with just a cam swap.
I have some 8.1L injectors I'll sell you. $110 shipped.
Old Feb 26, 2007 | 12:01 PM
probably like 100 dry on stock 99 injectors with boltons only. But with some 8.1 injectors and 255 fuel pump you could spray 150+ no problem.
Old Feb 26, 2007 | 06:25 PM
Hunt&Fisherator
damn, I forgot the 99's had the smaller injectors...
