what jets to go whit ????????
Old Apr 10, 2011 | 05:33 PM
6.0tank's Avatar
Default what jets to go whit ????????
hey guys was up i got a tnt kit whit the power ring now im wondering what jets to go whit .....im trying to sprey a 150 shot but not sure if i should go whit tnts jet chart witch says to go whit 42n/25f and the nx kit is 62n/33f...............now keep in mind its a duel
Old Apr 10, 2011 | 05:34 PM
6.0tank's Avatar
im using nx jets
Old Apr 25, 2011 | 11:14 PM
LS1TRUCKGUY's Avatar
Jets ate jets... I would go by the tnt chart
Old Apr 26, 2011 | 12:13 AM
nonnieselman's Avatar
Look up robie the robot. He has a accurate nitrous jet calculator that has been really close for me.
Old Apr 26, 2011 | 05:21 AM
2007chevy5.3l's Avatar
Ive found that the NOS jets are a little different physically than the NX style jets. NX being more common. But as far as orphis size, id try using the jet calculator like mentioned and go from there. A wideband is very handy for nitrous too
Old Apr 26, 2011 | 06:47 PM
00rcsb's Avatar
I always use robie the robot. Hasn't done me wrong yet
Old Apr 26, 2011 | 08:22 PM
sprayedenali's Avatar
start with whatever your jetting chart you got with the kit says and change it as necessary depending on what the plugs tell you
Old Apr 26, 2011 | 08:39 PM
00rcsb's Avatar
also verify fuel pressure. I know on nitrous outlet there settings are way rich
Old Apr 27, 2011 | 06:40 PM
00rcsb's Avatar
Originally Posted by graham@nitrousoutlet
Every nitrous company out there is going to be rich. There is no way around it.
We have to make sure the system is safe for EVERY car that it gets bolted on to. Not too mention NA tunes can play a big part in it as well. I've seen NA tunes on LS cars vary from 12.6-13.2. So clearly the AFR on nitrous would very a lot as well.
There will always be power left on the table. But this is why we encourage plug reading and learning to tune some what so you can safely extract all the power of the system.
I understand. But was laying it out there as I do run your plate kit. And just by reading the plugs for your stock setting I have to drop down fuel sizes alot (especially with a/f readings on dyno) I just think you guys are richer than I prefer on a kit. BUT all good nitrous kits still require finally tuning from the user.
simman22
Jan 21, 2017 10:27 PM
natejk
Nov 15, 2016 08:05 AM
1slwgto
Oct 1, 2015 01:51 PM
Rockrz
Sep 13, 2015 12:22 AM
custm2500
Aug 22, 2015 11:46 PM
