wet/dry other options?
Old Jul 8, 2007 | 05:28 PM
06sierra5.3's Avatar
Default wet/dry other options?
can someone send me a link to a post if there is one, or answer my questions. im 5.3 N/A ill have heads, cam, intake etc. shootin for low 13's/high 12's n/a. this is daily driven. what is recommended for my truck?
whats the difference between wet and dry shot
whats a fogger system
what other setups are out there (nothing crazy)
Old Jul 8, 2007 | 05:58 PM
2004SSS's Avatar
wet is nitrous and fuel injected into the intake system using a jet for each one. dry is just nitrous so extra fuel will be needed in a tune. direct por tis the way to go but isnt cheap youll have a wet system for every cylinder injected directly into the combustion chamber. giving it an even mixture all across the board. i did a spray bar set up on my vic jr that has a wet system set up using two spray bars right before each cylinder. very similar to a direct port but a little different.
Old Jul 8, 2007 | 07:07 PM
so with a wet system, i would have my fuel pump supplying my injectors, AND another line to a nitrous nozzle. do you upgrade your pump, or what. and an entry level wet setup would be one nozzle into the intake tube like ive seen on a few cars? do you tap into your fuel line. where do you get your fuel supply from for a wet shot.
Old Jul 8, 2007 | 07:09 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yeah, the fuel and nitrous Y into the intake tube.
Old Jul 8, 2007 | 07:12 PM
2004SSS's Avatar
i was getting it from the test port on my fuel rail. you can pull the scrader vavle and get some fittigns to adapt it.
Old Jul 9, 2007 | 01:02 AM
for a direct port, would i tap into each runner on the intake?
Old Jul 9, 2007 | 08:23 AM
2004SSS's Avatar
yes indeed.
Old Jul 9, 2007 | 02:58 PM
cool thanks guys.
thompson
Dec 27, 2017 06:48 AM
zblee
Nov 11, 2015 12:41 AM
carid
Oct 28, 2015 08:24 AM
TrickTurbo
Sep 25, 2015 11:22 AM
Closer_2001
Sep 24, 2015 09:15 PM
