went to track with the 07 max
Old Feb 21, 2009 | 02:28 PM
litreddevil's Avatar
Banned
Default went to track with the 07 max
well i tried spraying it with a 100 day and man did it bog,bad afr went from 12.9 to 10.0.
i was able to run a 14.51 in street trim took nothing out and had 2 full bottles in case the spray worked spare tire and my lap top.it got a 2.12 60'
i tried spraying it out the hole it went a 2.43 60'.
is my maf sensor to close and it is freezing i don't understand
thinking of going back to the wet kit it worked great before with a 150 shot
Old Feb 21, 2009 | 07:31 PM
slowprocess's Avatar
Sounds like you're freezing the maf........we had a similar problem on eli's truck back in the day before we moved it back off some. Then it hit good.
Old Feb 21, 2009 | 08:19 PM
built408's Avatar
had the same problem on my truck, it would freeze and then just fall on it's face. I just abondoned it and went with a wet kit.
Old Feb 22, 2009 | 12:18 AM
nonnieselman's Avatar
you try a smaller jet?
Old Feb 22, 2009 | 09:18 AM
Banned
no did not try a smaller jet did not have them with me but i can not move it back any it is in the air filter cap pointing stright in.
AdaMax
May 16, 2016 11:35 PM
Vortec350ss
Jan 12, 2016 10:36 PM
Wolftrk99
Oct 2, 2015 08:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Slammed silverado
Sep 28, 2015 06:14 PM
