Purge question
Old Feb 20, 2009 | 11:31 AM
GMCDee's Avatar
Default Purge question
Where do you all hook your purge noid up at and do you run the mail line to the purge noid first? I have it hooked up to the N2o noid now and when i purge i see no white plume even. I just had the bottle filled also theres air coming out of it but no N20. Any help or pics of a setup would help. Thanks gents
Old Feb 20, 2009 | 12:03 PM
slowprocess's Avatar
You have the correct location for mounting the purge. What is the outside temperature where you're purging.......The more hot and humid the temperature, the more noticeable the white plume. Also feel your purge noid after you've hit it a few times. If its extremely cold after a few hits, it should be working properly.
Old Feb 22, 2009 | 01:08 PM
tikkigodman's Avatar
yeah i thought the same thing until i got my bottle warmer,now the cloud is noticeable even at cold temps.it helps to notice the cloud cause some dumbass at summit accidently filled my bottle half full with compressed air.
Old Feb 23, 2009 | 03:26 PM
GMCDee's Avatar
I live in AZ so its pretty warm here but i still have no white plum. And it takes more then a few hits for it to even get alittle cold. Where should i start looking for promblems? Ill go fill my bottle again just to make sure its full. And just to make sure the label is supposed to be up right?? Thanks for the help gents
JordanH
Dec 25, 2015 08:32 AM
1slwgto
Oct 1, 2015 01:51 PM
gavin2005
Sep 13, 2015 09:04 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
