Went out tonight to test the nitrous.......
Old Nov 22, 2008 | 08:08 AM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by viciousknid
Earth.... ground.... I don't get it?
you need a VERY long extension cord.
Old Nov 22, 2008 | 08:31 AM
dewmanshu's Avatar
Moderately Differentiated
Old Nov 22, 2008 | 08:34 AM
dewmanshu's Avatar
If you have a "lighted" arming switch then it will need a ground (earth) as well. I am also assuming your 2 solenoids are fuel and nitrous. If one is a purge, then this will not work (you will need a seperate hot from a relay going to it). I also just drew the relay for quickness, I am not sure of the ACTUAL pin placement.
Earth isn't typically used as terminology for a ground in a vehicle or ship.
Old Nov 22, 2008 | 09:03 AM
dewmanshu's Avatar
here, drew this up to. Simplest form...arm it, push button to fire it. Use the same diagram for the purge (yes, you need a separate relay).
Old Nov 22, 2008 | 09:52 AM
03sierraslt's Avatar
Wow this is like the Bill Cosby Picture pages...... haha
Old Nov 22, 2008 | 10:32 AM
KySilverado's Avatar
Earth = Ground
Don't know what you have in mind.... but if the push button is for purge, ummm... you have it all wrong. If this is a wet kit, solenoid for fuel and nitrous. This will work.
Old Nov 22, 2008 | 10:44 AM
Damn, Dewey threw in 3 posts in the time I scratched mine up.
Old Nov 22, 2008 | 06:50 PM
A Low Dime's Avatar
13 Second Truck Club
HAHAHAHAHAH, there is no purge, just fuel and nitrous solenoids.
Just like I figured, the way I have the positive and grounds arranged is wrong.
Old Nov 22, 2008 | 07:22 PM
00ChevyScott's Avatar
Wearin' da big hat
dumbass
Old Nov 22, 2008 | 07:24 PM
A Low Dime's Avatar
Which one of you guys is right?
KYSilverado-you say my sketch is right with my arming switch having one positive and ground.
Dewey- You say my arming switch needs to have a 12v positive instead of a ground along with the positive from the relay.
