Went out tonight to test the nitrous.......
If you have a "lighted" arming switch then it will need a ground (earth) as well. I am also assuming your 2 solenoids are fuel and nitrous. If one is a purge, then this will not work (you will need a seperate hot from a relay going to it). I also just drew the relay for quickness, I am not sure of the ACTUAL pin placement.
Earth isn't typically used as terminology for a ground in a vehicle or ship.
Earth = Ground
Don't know what you have in mind.... but if the push button is for purge, ummm... you have it all wrong. If this is a wet kit, solenoid for fuel and nitrous. This will work.
13 Second Truck Club
Which one of you guys is right?
KYSilverado-you say my sketch is right with my arming switch having one positive and ground.
Dewey- You say my arming switch needs to have a 12v positive instead of a ground along with the positive from the relay.
