Tps Issues with Dr.X Harness?
Old Oct 7, 2010 | 11:05 PM
  #21
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
I hook to the TPS wire on every install I do. The key is a good clean connection.
Dave
Old Oct 8, 2010 | 09:14 AM
  #22
lt1s10's Avatar
Is there a way to read TP comanded and TP actual?? I know the mefi/egc motors can display it. Ive never played with the truck stuff... It could help rule out a couple things.
Old Oct 8, 2010 | 09:21 AM
  #23
DrX's Avatar
DrX
Commanded is determined by the pedal position and throttle response tables. You can log pedal position and throttle position. If they do not agree within a given %, a fault will be triggered. Some poorly designed electronics can mess up the TPS signal if tapped into it.
smokeshow
Aug 23, 2015 08:23 PM
fillpot
Jul 26, 2015 07:21 PM
mr03silverado
Jul 17, 2015 02:15 PM
skylark
13
Jul 11, 2015 12:54 PM
GreyChevy
Jul 7, 2015 08:57 PM
