throttle body plate
Old Nov 30, 2008 | 01:20 PM
litreddevil's Avatar
Banned
Default throttle body plate
i am looking to see who makes 95mm and 110mm throttle body plate for the spary i am thinking of making the plate my first stage and my dp my sec. stage.
thanks
Old Dec 2, 2008 | 02:27 AM
silver-mod-o's Avatar
Hunt&Fisherator
Randy, if you're running a Vic Jr just use a carb plate under your elbow IMO
Old Dec 2, 2008 | 09:42 AM
TrickTurbo's Avatar
Truck Sponsor
We can build you a plate no problem, just need some picks and a drawirng or the parts you want the plate to fit.
Old Dec 3, 2008 | 12:02 AM
built408's Avatar
you would get better distribution if you use a carb style plate under the elbow. That is if you are using a carb style intake.
Old Dec 3, 2008 | 08:31 AM
Banned
i was told that the further away from the intake the better mixture i would get.
Old Dec 3, 2008 | 09:16 AM
Hunt&Fisherator
I think that would depend on how the spray bars are actually set up in the plate... I don't see where either one would be better than the other to be honest.
You're going to get an even amount of air/nitrous to each cylinder since you're using a single plane intake anyway.
I personally think a carb plate would be the way to go in your case...
Old Dec 3, 2008 | 06:16 PM
built408's Avatar
Ive never seen anybody use a tb plate when using a carb style intake. The carb style plates offer alot more even distribution.
Old Dec 3, 2008 | 08:42 PM
ZR1 DREAMING's Avatar
Randy, when I was going to run my Vic Jr I had looked into the same thing. IIRC I beleive Wilson manifolds had a 105mm plate.
I have in several different apps. They use an elbow to a 90mm TB which has a Nitro Dave's plate inbetween the TB and the elbow. If I were to do it again I'd run the Edelbrock 4bbl TB with a 4150 plate underneath.
Old Dec 3, 2008 | 11:40 PM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
I have a 100mm sitting on the shelf. We can make you anything you need.
Dave
Old Dec 4, 2008 | 06:41 PM
Banned
Dave
what is your opinion on the carb set up are the throttle body set up. what is better
flatblack83
Jan 3, 2026 07:10 PM
lucas287
31
Jan 12, 2021 06:18 AM
blownss27
Aug 14, 2020 08:27 AM
pewter00
Dec 13, 2015 10:38 PM
99bluefirebird
Sep 17, 2015 08:05 PM
