window switch or tps switch
Old Dec 10, 2008 | 12:47 AM
bigred06's Avatar
Default window switch or tps switch
I just got the nitrous works efi kit and it comes with a micro switch. My truck is a 2007 silverado nnbs Ive never done nitrous and will like advise. I gonna run 100 shot for now so if any body could tell me the difference thanks
Old Dec 10, 2008 | 12:22 PM
LMSeven's Avatar
A Window switch basically allows you to spray during a certain RPM range, like 2700-6000 RPM. A TPS switch is a throttle position switch, what it does is only lets you spray when your at wide open throttle, you splice wires into the throttle body and when throttle position reaches 100% it will allow you to spray. Your micro switch will act like a TPS switch, as in when it clicks it 'see's wide open throttle'. Mine is mounted on the gas pedal, and only clicks when I bury the pedal.
This has a TPS switch, window switch, air/fuel switch, and plenty of other features. I'm buying one. http://www.harrisspeedworks.com/shop...cat=308&page=1
Old Dec 10, 2008 | 02:43 PM
bigred06's Avatar
will the msd one work or is the harris one better
Old Dec 10, 2008 | 03:11 PM
TrickTurbo's Avatar
Truck Sponsor
Window switch is a must with any nitrous system. Here is an option for your over the msd part. This includes dual channels and a tps switch. Let me knwo if there is anything I can help you with.
http://www.trickperformanceproducts.com/tpp_00011.htm
Old Dec 10, 2008 | 03:17 PM
krambo's Avatar
I like the one from Harris however I got the P gauge from Trick --> http://www.trickperformanceproducts.com/tpp_00019.htm
Old Dec 10, 2008 | 03:24 PM
Nick@HSW's Avatar
FormerVendor
Any of them will work...it really depends on the features that you want. If you're looking based solely on price, take a look at the sale thread in this section. Might be able to save some money that way. Thanks!
Nick
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
Closer_2001
Sep 24, 2015 09:15 PM
jtphelps289
Sep 1, 2015 08:58 PM
