Stand Alone System questions
Old Oct 12, 2009 | 11:25 PM
nonnieselman's Avatar
Default Stand Alone System questions
on my S10 my fuel cell has 2 outlets on the Sump.
one side is feeding the fuel rail and a 50 shot off the rail.
I have a Aeromotive FPR and another Inline 255 im goin to run for the other 2 big kits.
What would yall set the pressure to for the nitrous side?
The engine side is goin to be using a 99-02 Return rail. so once i get a reading on that to make sure its ~60psi ill know what jets to use.
Should i run the Aeromotive FPR at 60psi also? i think it maxes out at 70psi.
Depends on how it hooks, first kit is goin to be a 125, second a 75 and a third kit 50..
if it doesnt hook then ill swap the 75 first and the 125 second.
Cammed 4.8 on 116oct
Old Oct 20, 2009 | 08:04 PM
Old Oct 30, 2009 | 05:44 PM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
Are the systems non directport? How much are you spraying on each stage..
Dave
Old Oct 31, 2009 | 08:51 AM
custm2500's Avatar
Ph.D. in HUBRIS
If 70 psi is the max I would stay at 55-60. No need to push the pump near it's limit since you can just change the jet.
Old Dec 1, 2009 | 06:17 PM
Dave
Just a plate and a nozzle.. 75 on the plate and 50 on the nozzle till i get the tune sorted out then ill slowly up both shots.
I think im just goin to go with 45psi and hook up the vacuum reference so when i put the turbo on it should be good to go.
Sorry for the late replys, i dont get on the net much anymore..
Thanks!
Old Dec 1, 2009 | 08:03 PM
MPFD's Avatar
11 Second Truck Club
Call and ask the maker of the plate your using. I use NX shark nozzle's and Nitrous Express told me 10 psi would be perfect.
Old Dec 1, 2009 | 08:19 PM
i cant remember who makes it, i have 3 of them. i know one is a old nitrous outlet, and i think one is a nitrous express, and the other is a home made one.
Old Dec 1, 2009 | 08:22 PM
MPFD's Avatar
http://www.nitrousexpress.com/Instru.../flowcheck.pdf
Old Dec 19, 2009 | 02:15 AM
sprayed99's Avatar
the jetting changes from a low pressure (7-15psi) to a high pressure (55-65psi)
You need a base chart to go from then good tuning.
USMCvet0311
Aug 1, 2015 07:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
FlowmasterMufflers
Jul 9, 2015 12:00 PM
Nimoryan
Jul 5, 2015 03:50 PM
