Stand Alone Fuel System "DONE"
Old Jan 15, 2009 | 10:20 AM
  #31
philntx's Avatar
Originally Posted by built408
Was wondering about the battery box? Is that stock on a SSR?
Here's a pic of an SSR without a body: Battery box is in the right corner.
Old Jan 15, 2009 | 11:10 AM
  #32
leftcoast32's Avatar
FormerVendor
The SSR has a shortened TrailBlazer frame so it was a bolt in for the most part. I had to fabricate a bracket from the box to the frame. The SSR frame has a riveted bracket so I just had to make a bolt on one for mine.
Old Jan 15, 2009 | 04:06 PM
  #33
FormerVendor
Here is the Relay/Junction Center I made because of all the different systems I run with Key On Power. This is all right behind the drivers side headlight so it is easy to service all of the different systems.
There are 2 seperate junction blocks with 2 posts on each side of the relays. The one on the side you can see is just the positive junction block.
The power is pulled from the post on the fuse box with two 8 gauge feeds to the junction block. The ground is pulled the same way from a chassis ground to the other junction block.
The negative junction block is at the other end of the relays and looks the same as the positive one.
We made up a steel plate with drilled and threaded holes so everything is attached with stainless button heads.
The feeds to the relays from the junction block each have fuses in line. The feeds for power to the heavy side of the relays are all 10 gauge as are all the feed for the different systems.
I just finished it up and tried to get a better picture. I will run the main power and trigger for the fuel system later once I install the rest of the nitrous components.
Old Jan 19, 2009 | 09:15 PM
  #34
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
Wow. That is one clean set up. Do you have pictures of the entire ride?
Dave
Old Jan 19, 2009 | 09:29 PM
  #35
LoweredZ71's Avatar
Is it just my eyes or is the serp belt shiny!?
Old Jan 19, 2009 | 09:59 PM
  #36
FormerVendor
UnCoated Billet Pulley's will do that to the smooth side of the belt.
Dave
Here are just a few of the pictures.
Old Jan 20, 2009 | 08:38 PM
  #37
That thing is show quality. Awesome work!!!
Old Jan 20, 2009 | 09:13 PM
  #38
LEADING EDGE PERFORMANCE's Avatar
FormerVendor
Joe. As always First class. Just the way we like it!!!!!
Garth
Old Jan 20, 2009 | 10:08 PM
  #39
FormerVendor
Thanks!!
RONIN LSX
Aug 10, 2015 04:45 PM
TAPyvehc93
Aug 8, 2015 06:35 PM
MS3Z
Jul 30, 2015 06:17 PM
4B11T
Jul 13, 2015 03:48 PM
