Spraying Pro Flo?
Old Dec 1, 2011 | 10:21 AM
Vortec HD's Avatar
Default Spraying Pro Flo?
Anyone spraying a Edelbrock Pro Flo Intake?
Want to install a plate kit, but all I read about is that a Plate kit in not good for that intake because of the 90* and direct port is the only way. Will be only using up to a 100 shot.
Old Dec 1, 2011 | 11:09 AM
tarinitup's Avatar
9 Second Truck Club
Works exactly the same.
Old Dec 5, 2011 | 05:11 PM
JoeyGC5's Avatar
I was going to run a 90mm plate on my Pro-Flo manifold and Edelbrock throttle body, but I already had the nozzle kit installed on the truck.
Old Dec 20, 2011 | 02:11 AM
ChevyLee's Avatar
twin terbies
You can't run a plate. You have to do dp, it's because of the short runners. They don't give enough time for the gas and fuel to mix and which ever cylinder is getting ready to fire when you hit it will get most of the dope and gas. This will cause a back fire which will pop a motor real quick.
It happened to a friend of mine.
Old Dec 20, 2011 | 02:24 AM
CC05's Avatar
https://www.performancetrucks.net/fo...see-em-482990/
Take a look here. Should pretty much answer your question.
Old Dec 20, 2011 | 05:35 PM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
We have plumbed many of them with Directports. I personally think our plate would work fine on them up to a certain hp level. How much are you trying to spray?
Dave
Old Dec 21, 2011 | 01:30 PM
fastrt's Avatar
11 Second Truck Club
I think DBrods had a problem with his.
Old Dec 21, 2011 | 05:29 PM
John at DB Rods is a friend of mine. Ill call him and ask tonight.
Dave
Old Dec 21, 2011 | 05:39 PM
ChevyLee's Avatar
twin terbies
This is who I was talking about.
Jon ran the pro flo with a plate. It did not work. I had the pro flo on my truck for a while, and I switched to another intake so I could spray.. If you go DP it will be fine, but as far as a plate I personally wouldn't do it. I believe Jon was spraying a 175 shot when he ran into this issue.
twake_410
Apr 14, 2016 09:58 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
someotherguy
Oct 5, 2015 12:49 PM
sprayed99
Sep 14, 2015 12:36 PM
