Rich-Lean Switch?
Old Feb 6, 2011 | 04:04 AM
Steve-O-08's Avatar
Default Rich-Lean Switch?
I know DynoTune makes a Lean Shutdown Switch, Does anyone make a lean-rich shutdown switch? OR Is there a way to use a wideband gauge or controler to do the same?
Old Feb 6, 2011 | 11:02 AM
SRTKLLR's Avatar
Don't you have the HW stuff? I think their MicroEDGE has that feature.
"A/F Shut Down Switch: Nitrous system(s) will shut down if a lean condition is detected by either a wideband O2 sensor or narrowband O2 sensor. The MicroEdge+ will also shut down the system if an overly rich A/F is detected (wideband sensor only)."
As an alternative you can just get a FPSS(Fuel Pressure Safety Switch) if you are running a wet kit. If your fuel pressure drops too low(whatever you set it too) it will shut off the nitrous. It costs between $35-50 depending on which one you need.
BTW, could you help me finish up the wiring on my nitrous kit?
Old Feb 6, 2011 | 12:17 PM
Steve-O-08's Avatar
Already running a fuel pressure safety switch, I already have a FPSS, but I was looking at other options as well. Yeah I have an HSW kit but I'm not very happy with their customer service. Remember the microedge has that feature just wondering if anyone else has something similar.
Where are you located?
Old Feb 6, 2011 | 12:39 PM
SRTKLLR's Avatar
I have the Nitrous Outlet Digital Progressive Controller and just looked and it also comes with a "lean cut off feature".
Here is the info on it.
Nitrous Outlet Digital Progressive Controller with built in window safety switch, tps activation, gear lock out features and automatic lean cut.
* Nitrous Outlet's Progressive Contoller is an affordable, compact, and easy to use controller.
* Will easily fit into small spaces giving you more flexibility in install options.
* Hi amp continuous duty circuits
* No computer needed!
* Adjust Start% and Build Time.
* Reset option for clutch cars.
* 40 amp capable draw.
* 2 independent RPM activation and RPM deactivation.
* 1 progressive channel
* Lean cut off feature (wideband required).
* TPS activation for falling signal, rising signals, low voltage signals, irregular signals and mechanical wide open throttle.
* Multi Gear lock Out Feature allows delaying the stage from activation.
* Can be used as a progressive controller only or use all controller features.
* Ground & Hot Output wires allow multiple accessory activations for use with timing retards, indication lights etc.
* Digital Hand Held Controller with LED read out for ease of programming and diagnosis, Conforms Vehicle RPM, Shows wide open throttle activation, shows gear lock out status, and shows activation status.
They have excellent customer service and are a vendor here as well.
I live in the IE but can drive to where you are at and you can help me wire the progressive.
Old Feb 6, 2011 | 01:28 PM
Steve-O-08's Avatar
I have a Wide Open Throttle/RPM Window Switch from Nitrous Outlet and they have great customer service. I am probably going to make the switch to them. Right now I don't have any of my system in because I had an issure with a purge solenoid. Going to move some stuff around and re route some wiring. I don't have a whole lot of room to work right now, but if you do, I can come help you out.
Old Feb 6, 2011 | 01:34 PM
SRTKLLR's Avatar
If you haven't used the window switch yet you may be able to exchange it for the progressive controller and just pay the difference.
I have plenty of room in my driveway and/or garage.
Old Feb 6, 2011 | 01:41 PM
Steve-O-08's Avatar
Well it was already hooked up so that's out. I was looking at the DynoTune Lean Cut out Switch but I'd like to have a rich cut out too.
Cool I may have some time next weekend. Just wondering, have I seen your truck at Irwindale? There was a truck there that looked like the one in your sig, but I think it had some orange decals on it.
Old Feb 6, 2011 | 03:04 PM
SRTKLLR's Avatar
Yeh , that was probably me. It came with factory Red(Orangy) 400SS stickers on it.
Old Feb 6, 2011 | 03:38 PM
Steve-O-08's Avatar
Oh ok cool. You have a pretty nice truck from what I remember of it.
Old Feb 7, 2011 | 11:18 PM
Steve-O-08's Avatar
Anyone have any more info on this?
