Quick Question
Old Apr 22, 2007 | 11:21 AM
RedHot04's Avatar
Default Quick Question
Could I use one of these with F/I setup that I have? Any problems with spraying BEFORE the
S/C instead of at the TB ?? Didn't research yet just figured someone has already thought about it. Thanks ya'll.
Old Apr 22, 2007 | 06:30 PM
southern_chevy's Avatar
Why not just put a nozzle after the s/c? But if that is what you are wanting to do, I would think it would be fine since it is a dry shot.
Old Apr 22, 2007 | 06:42 PM
nightrunner's Avatar
Mr. Obvious
it would be better to spray after the SC because then you get more of a cooling effect from the nitrous on the compressed (HOT) air and usually will net you more gains than what the jet is rated for, example a 50 shot gains about 60-70 rwhp
Old Apr 22, 2007 | 10:23 PM
RedHot04's Avatar
Although it should produce more power after S/C, I am running a FMIC and my other objective is to try and cool the head unit some too by spraying at the MAF instead of the traditional way @ the TB. Any more thoughts on this, good- bad or otherwise...
Maybe a dual nozzle approach with one at the Filter and another at the TB?? I'm still sittin on the meth too for right now I'm kinda lost on the path between power AND cooling. Gimme some ideas please. I'v been watching trever1t on the 35 shot setup he just got going and Wilderacing with the 3 nozzle meth setup he has and all this makes me just a little thirsty !
Old Apr 23, 2007 | 01:54 PM
silver-mod-o's Avatar
Hunt&Fisherator
put a wet nozzle after the supercharger and use a spray bar for the intercooler IMO... spray bars can be built pretty easily... you dont need to buy one IMO..
Old Apr 23, 2007 | 02:55 PM
RedHot04's Avatar
Really want to stay with the dry (HSW) But, I also want to reduce some of the heat soak in the Supercharger head unit, spinning it @ 48k isn't real good to start with! I know this all may sound kinda odd but... As for the I/C I think it's doin a good job, the piping goin to the TB is usually cool. Thanks for the feedback guys, keep em' comin.
Justin87gn
Sep 10, 2015 12:06 PM
custm2500
Sep 8, 2015 05:53 PM
bisqikss
Sep 8, 2015 03:35 AM
SWINGRRRR
Sep 3, 2015 07:49 PM
mr03silverado
Sep 2, 2015 11:43 PM
