Plate vs nozzle?
Old Nov 25, 2009 | 11:30 PM
Wyttrash96's Avatar
I hate my cats
Default Plate vs nozzle?
I'm getting close to installing the nitrous in my console. I don't have a way to actually get the juice into the engine yet though. Should I buy a cheap egay tb spacer and drill it for a nozzle, bite the bullet and buy a 78mm plate, or really go ape and hide a fogger underneath my intake? Any and all input is appreciated.
Old Dec 5, 2009 | 12:45 PM
Burgundy&TanMan's Avatar
Well i guess that all depends on what you want to spend, I run a nozzle and have had good results with it. But if i were gonna do it again i would probably go with a plate and I may just do that in the end.
Old Dec 5, 2009 | 12:54 PM
dirt track racer 81's Avatar
A plate can still be somewhat be hidden.
Old Dec 5, 2009 | 01:59 PM
whatever you do don't get a throttle body spacer and tap it with a nozzle, I ran 2 bottles through my truck like that and it bucked at popped at upper rpms. Also my tuner made me aware that the nitrous isn't atomized enough before entering the manifold and is just shooting into it and missing the first two cylinders. some sponsors of the site have great plates available.
Old Dec 5, 2009 | 02:18 PM
TXsilverado's Avatar
nitrous outlet plate. you wont regret it. im on my third.
first one was a single 78mm plate
2nd was a single 90mm plate
now i have a dual 90mm on the way.
look up wheatleys install pictures. he got my old 78mm plate and threw some 3 piece covers over it and HIS ENTIRE NITROUS SYSTEM IS HIDDEN. very clean install.
Old Dec 5, 2009 | 02:26 PM
Black'Rado's Avatar
^u got a link to those pics?
Old Dec 8, 2009 | 12:44 AM
bad intentions's Avatar
i would think the plate would work best for are trucks/ or any engine. i used a shark nozzle drilled to my intake when i 1st got some spray.
Old Dec 8, 2009 | 12:54 AM
TxStVanWilder's Avatar
i use the nitrous outlet plate on my truck
with the regular engine cover (1 piece) on you cant see the plate and there are plenty of spots and ways to hide your solenoids and lines
Old Dec 10, 2009 | 10:12 PM
how about the pics? ls6 plate on a truck manifold and 3 piece cover.
NOW YOU SEE IT:
ABBA-CADABARA AND *POOF* IT'S GONE
Old Dec 10, 2009 | 10:20 PM
2005 Silverado's Avatar
SPAM HUNTER
I used that same brand for a kit i had a while back, with the cover on it at night you couldnt tell i had nitrous on it
noids
plate
