Plate set up
Old Aug 18, 2006 | 10:57 PM
TURBO8's Avatar
Default Plate set up
Do they have a plate system that will give only a 35-50 shot? All the plate systems I see are for 100 and up. I just want the plate, I have a nos kit already.
Old Aug 19, 2006 | 07:09 PM
litreddevil's Avatar
Banned
man you made 622 hp with a 5.3 what kind of plate r u looking for a tb r a carb
Old Aug 20, 2006 | 12:58 AM
TURBO8's Avatar
I know the plate is overvboard but I like the setup because I dont want to have another hose sticking out of my intake tube. Plus it looks cleaner. I just want to do a 35-50 shot to help me out of the hole. I plan on just useing a button to spray in first only. I am ok during the rest of the run. I am looking for a tb plate, stock tb size that can shot a 35-50 shot. All I have seen is 100 and above. I wonder if you use the same jets as the nossle? Just installed into the plate? I dont know much about NOS. Need help.
Old Aug 20, 2006 | 01:35 PM
Z284thgen's Avatar
11 Second Club
nitro dave makes a LS1 plate
should be the same for the truck someone correct me if im wrong
Old Aug 20, 2006 | 04:43 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Yeah the plate goshawk has should fit the bill the fine.
Old Aug 20, 2006 | 08:18 PM
TURBO8's Avatar
thanks guys.
Old Aug 21, 2006 | 04:49 PM
goshawk23's Avatar
Truck addict
it's a nice plate. i like it a lot.
Old Aug 21, 2006 | 05:33 PM
Z284thgen's Avatar
11 Second Club
well spill the beans on what it is i have been lookin at them lately as well
Old Aug 21, 2006 | 06:08 PM
goshawk23's Avatar
Truck addict
the image speaks volumns. bad *** plate. for truck guys you will have to custom fit the throttle cable bracket that comes with the plate unless nitrous outlet has had a chance to work with the truck intake. also there is a sensor on top of the truck intake that will need to be removed. it can be turned off in your computer program since it's a sensor you can live without.
i have sprayed a 200 shot through the plate and it delivers fine. the jet chart that comes with the plate is a tad on the safe side as far as fuel jetting goes. most people run a jet smaller on the fuel but to get the correct a/f ratio you need to wideband it. i run it like it is. i don't mind being a little fat. um, it's easily hidden under the engine hat. so if you want a hidden setup this is the route to go.
Old Aug 21, 2006 | 07:20 PM
Z284thgen's Avatar
11 Second Club
so you have one of dave plates i take it
