NX wet kit jet question
Old Feb 2, 2014 | 10:41 AM
gbbmk's Avatar
Default NX wet kit jet question
I am installing a Nitrous Express kit I picked up second hand and i am new to the nitrous world. I want to install a 75 shot. The jets suggested for my motor is 41 nitrous and 23 fuel. I have a 41 for the nitrous side but I only have a 24 for fuel right now. Can I run the bigger fuel or should i wait until I get the correct size jet. I am going to the dyno tomorrow and I wanted to have this ready.
thanks for the help
Old Feb 3, 2014 | 09:06 AM
NitrousExpress's Avatar
Former Vendor
thanks for the help
You can run it, but it will be rich and you will be leaving some power on the table.
Trey
Old Feb 3, 2014 | 11:45 AM
Turbo09's Avatar
I would run it and check the plugs, and go from there. I have found some of the recommended jets to be a little on the conservative side, I have only dealt with NOS though.
Old Feb 3, 2014 | 12:55 PM
Blwn99x's Avatar
^ this, then once its working...switch to a 52/28 jetting lol
Old Feb 3, 2014 | 07:39 PM
gbbmk's Avatar
Well I just got back from dyno and I was happy with what it did considering it was rich. I went from 323 to 387 on a 75. And my bottle pressure was down. the timing is set at 24 to be conservative for now. I am installing the 52/28. or should I go to 125 shot? What is the jetting on that? This stuff is addicting. Not bad for my first try with juice. Oh this is a 4wd also in second gear. Best part is this is a work truck with a ladder rack and tool box.
Old Feb 4, 2014 | 09:37 AM
Turbo09's Avatar
Love the ladder rack, the super sleeper.
There are a few online calculators but Its best to call NX and have them tell you then you know its safe, I was running a 42. 24 on my BMW being a 2.5 6cyl that was around 120 shot
Old Feb 4, 2014 | 09:42 AM
Turbo09's Avatar
P.S. its extreemly addictive, and its best to do your tuning and spark plug checking on a regular bottle pressure say 900psi. 200 psi higher can cause you to go scary lean and 200psi lower will loose quite a bit of power and look extreemly rich. Just keep checking the plugs! they tell the story
Old Feb 4, 2014 | 10:42 AM
Blwn99x's Avatar
if you dont have one, get a nitrous press gauge, at the bottle or in cab, this will help to tune properly and have consistent horsepower
5.3lSilverado
25
Aug 29, 2016 12:48 AM
urdone
Aug 18, 2015 12:17 PM
USMCvet0311
Aug 1, 2015 07:45 AM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
