Nozzle Placement??
Old Jan 2, 2011 | 10:23 AM
Half-bred's Avatar
Default Nozzle Placement??
I installed a dry kit on my truck, First I had the nozzle at the very end of my Cone air filter, It has a cold air intake. I ran the truck a couple of times and the A/F was reading 13.2 but when I ran the truck N/A the A/F was 10.8 so I moved the nozzle closer about 3in away from the mass air and now it went to 14.3. where should the nozzle be? Anyone out there have any pics of where they placed theirs. Thanks any help would be great.
Old Jan 2, 2011 | 11:30 AM
Rhino79's Avatar
9 Second Club
Generally on a dry kit, it should be in the end of the filter. WOT afr on juice should be ideally in the mid 11's to high 11's and on all motor it should be mid 12's to low 13's
Old Jan 2, 2011 | 04:23 PM
LS1TRUCKGUY's Avatar
did it jump straight to 14.3 afr, or did it gradually lean out? you may be running out of fuel somewhere. do you have a fuel pressure guage?
Old Jan 4, 2011 | 04:46 PM
Half-bred's Avatar
No I dont, but that will be next thing, I just put a 255 pump in it. I was told that the placement of the nozzle is very important
Old Jan 5, 2011 | 04:27 PM
Steve-O-08's Avatar
I used the Harris Speed Works Interface controller with my set up. Great product. And I don't have to adjust the nozzle's placement to control fueling.
Old Jan 5, 2011 | 04:48 PM
Half-bred's Avatar
Thanks
Old Jan 17, 2011 | 11:18 PM
jmchevyman's Avatar
so generally on a dry kit, it is best to mount the nozzle before the maf? or after? on a stock vortec 5.7. i used to have the nozzle after the maf but was told to move it before the maf
Old Jan 17, 2011 | 11:22 PM
charcoal03silvy's Avatar
Before
Old Jan 17, 2011 | 11:37 PM
jmchevyman's Avatar
Originally Posted by charcoal03silvy
Before
thanks man, that was easy. ok 1 more for ya. will a custom tune turn the check engine light on? its off now with magnaflow cats and my awesome superchip tune! ha
GXPJAY
Feb 13, 2022 08:15 AM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
bgray
Sep 16, 2015 07:33 PM
custm2500
Aug 22, 2015 11:46 PM
