Nos kit for 5.3
Originally Posted by trever1t
Actually it is Nitrous Oxide, or N2O.
Movie didn't impress me either
Nitrous Oxide is N2O (the gas)
I used to get the question "you got nos on that thing" all the time. My reply was "No, it's a Compucar kit" all the time.
Bottom line; they're not the same thing.
i understand what your saying ranger. i get asked all the time too when people see the bottle under the seat. "you got naws in that truck" no is my answer. then i hear "well whats that bottle for? it's nitrous oxide. it befuddles the crap out of them
Originally Posted by silver-mod-o
I have a Harris kit as well.. but I'm not cool like Beau so I'll stick with my bracket that came with it...
if he found nitrous. I bought the heater kit, HSW wet kit, and bottle bracket, so next on the list is TR6s, blow down fittings, and QUICK DISCONNECT FITTINGS. Im hoping to be able to pull the bottle very quickly just in case.
If i knew i could get away with it, i would pass on the bracket.
Originally Posted by Soon2bSpooled
why dont you just mount the bottle under the truck inside the frame? old mans not gonna bend down and look there. iisnt he gonna notice all the steel braided lines and stuff?
put the bottle on the inside of the frame rail. nothing will happen to it there. too bad you dont have the stepside with the fender well lining. then you could put it between the bedside and frame and still be hidden. anyways, get the factory EGR plug and put the nozzle into the intake manifold right there. wire wrap will make all of the lines look like they came from the factory. 3 piece covers aughta hide all of the solenoids and nozzle perfectly.
what nitrous???
what nitrous???
sounds like a good plan beau. i wouldn't mind having some quick disconnects. then again, i want to mount my two bottles in the bed. i'll have to figure all that out first then work on the quick disconnects.
I figure if i have clean setup that i can take in and out in less than 20 seconds ill be happy. I really dont worry about my dad seeing it in the engine compartment. I also could give two ***** if somebody else sees it in my engine bay. "yeah i got gas, what of it?"
Since the bottle bracket is adjustable, a blow down fitting would keep the bottle stationary because the tube would have to change positions with the bottle. Therefore, i am making my own blowdown tube out of flexline and using a stainless bulkhead to mount it on the floorboard so i can not defeat the purpose of that bottle bracket. Ill get some pics of my setup when i finish it. Im figuring quick disconnects for everything.
Choda
Jan 22, 2026 02:03 PM
