nitrous question ????
Old Aug 30, 2008 | 01:13 AM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
Question nitrous question ????
what would be the best way to install a dual stage nitrous kit (25 off the line and then another 15 a lil bit later )
i would really like a throttle body plate but i can only find them in a single stage but i really like the way the Harris Speed Works plate sprays.... should i do the first stage in the plate and the other stage out of a regular nozzle before the t-body?
what options do i have beside direct port because i can't afford it...
p.s. i have a stock ls1 t-body and a ls6 intake
Old Aug 30, 2008 | 01:28 AM
aksz71's Avatar
why that small of a shot?
Old Aug 30, 2008 | 01:30 AM
it was sarcasm...lol it will be more like a 125-175 and a 75-150..
Old Aug 30, 2008 | 01:34 AM
aksz71's Avatar
o ok i was fixin to say why waste the money.. u going too run stand alone also?
Old Aug 30, 2008 | 01:41 AM
yes i'm sure i will run a HARRIS SPEED WORKS stand alone unless someone else knows a better or CHEAPER one...lol
Old Aug 30, 2008 | 01:45 AM
aksz71's Avatar
i like the nitrious outlet and if u have stock ls1 tb which is 78mm they have em there.. 359$ for the plate(dual)
Old Aug 30, 2008 | 01:48 AM
400 bux...WOW
how do the fuzions work??? ($229)
or just run the HARRIS SPEED WORKS single then a nozzle for the second stage
have you seen how the HSW plate sprays???? check it out on their site
Old Aug 30, 2008 | 01:52 AM
aksz71's Avatar
yes i have seen the plate and then nozzle would work good (cheaper)lol.. i have nozzle and been thinkin about plate but i believe if i do plate i addin another stage i mean i satisfied so far bone stock with a 125 wet hittin knock and ran a 13.9 in 1/4 not bad for a ext z71 and running 16.0 16.1 stock havent had a chance to go back too track here lately
Old Aug 30, 2008 | 01:56 AM
not bad at all...
i am building a regular cab s10 (97) with a fully forged 6.0L with ported heads and a healthy cam and a 4l60e
i'm looking for the 9's on a daily drivable A/C truck!!!
Old Aug 30, 2008 | 02:00 AM
aksz71's Avatar
too the best of luck man.. been thinkin about ditchin my truck this is the 3rd ext. z71 i have had and i only 20 lol been thinkin of dmax( to haul race car 72 vega fiberglass doors and front end and hatch, 355 w/brodix heads and high rise intake on alcohol etc.. 6.30's in 1/8)
