nitrous needs...help!
ok so i bought a dynotune dryshot for my 03 silvy and here are the questions...
1.will i get detonation with my hypershit powercrapper?
2.what should i NOT do once this is hooked up?
3.how do i keep the wifey from spraying when she drives it? (she's ******* stupid like that)
4 where the hell do i get a bottle filled in maryland? i live in the glen burnie area.
5 what is the deal with the tr6 plugs?
thank you i have 0 experience with nitrous and know very, very little about it....anything i forgot to ask that i should know it would be nice if you told me you know WARNINGS!! thank you all very much!!!!
get rid of the hypertech, it advances the timing and with nitrous you want less timing, but ive heard of some running up to 150shot on stock tune
get some ngk tr6 spark plugs
take the bottle out to keep anyone else from using it
2. I would not get greedy and put a real big shot in without proper tuning, and would not spray below 3k rpm nor through the shifts.
3. Make sure bottle is turned off.
4. No Idea.
5.You WILL need some "tr6" spark plugs to use with nitrous for safety reasons.
you can order some here
www.nitrousoutlet.com
you can get the TR6 plugs at your local auto parts store as well.
wire your setup through a push button (activation) and just keep the button disconnected and put away where she cant activate the system lol.
People say dont use handhields. But stock timing at WOT is like 15 MAYBE? Well I can 28* of timing on a 125 wetshot with the correct a/f, around 12.7. Their is no way any handhield advances timing to 28*. Nor does anyone run a 150 dry on stock fuel system and stock tune. And nightrunner that is what you get for thinking! haha
I highly recommend tr6 plugs. And a custom tune you will see major gains out of nitrous. No other way I would do it. OH and with the nitrous your stock tranny WILL bust even sooner.
I have ran a 100 shot on stock everthing.You will need some trans work though,I also used the ngk tr6 but other than that stock I put a fuel pump in when I moved up shots.This is a wet kit that I use.I am not a big fan of dry kits.I agree with 99silverado5.3 I would not run more than a 75shot with that dry system with out a tune
