nitrous afr
Old Apr 2, 2009 | 10:51 PM
mcfarlnd's Avatar
Un-Registered User
Default nitrous afr
what are yall running your afr's at while spraying?
Old Apr 2, 2009 | 11:08 PM
nonnieselman's Avatar
Old Apr 2, 2009 | 11:42 PM
dirt track racer 81's Avatar
This guy is a nitrous tuner for NOS and travels around tuning nitrous cars. He also has nitrous classes. His name is Monte Smith.
" I know the NOS suggested jetting is larger on the fuel and that will be dead rich. Will it run? Sure. Will it hurt anything? Likely not at these low HP levels. Are you getting near what you should from the kit? Absolutely not. It has been preached for years that "rich is safe" and most guys tend to believe it, but that could not be farther from the truth. Excess fuel just beats the crap out of the rings. 99% percent of nitrous related engines failures are from too much fuel, too much timing, or both. It is EXTREMELY rare to burn a motor by getting the nitrous system too lean. Barring a mechanical malfunction or an extremely bonehead tune up change, that is nearly impossible to do.
As far as A/F numbers, for some reason, people seem to think nitrous motors need to run way richer than they do in N/A form...again, not true. As an example, if your motor makes best power N/A at around a 13:1 A/F ratio, a moderate nitrous tune (less than 250 hp) will be fine at that same 13:1 A/F ratio, provided you get the timing correct. Although I would not suggest you go straight to these numbers, I run the 632 in the drag radial car, at about 13:5.1 A/F ratio, with about 600hp worth of spray. The Pro-Mod car also runs over 13:1.1 with over 900hp worth of juice. Anything in the 9,10, or 11 range, on spray, is DEAD RICH."
Heres more off his site http://smotherssupercars.com/nitrousclass.html
Old Apr 2, 2009 | 11:46 PM
my AFR in boost is ~ 11.2 and i just havent found the pressure where 11.2 spraying is at.. so i just spray it rich.
Old Apr 3, 2009 | 08:11 AM
mcfarlnd's Avatar
Un-Registered User
thats some great info. mine is in the mid 11 range and apparently i have some work to do. thanks dirt track racer.
Old Apr 3, 2009 | 08:25 AM
03tahoe22's Avatar
I thought most boosted applications were in the 11.2-11.4 range..... So is it ok to Spray and mantain this afr?
Old Apr 3, 2009 | 09:42 AM
mcfarlnd's Avatar
Un-Registered User
basically from what i understand is that when spraying a smaller shot, if your running your wot afr at 11.4:1 when not spraying then when spraying you should see similar afrs on the spray. i would think its ok. do not go 13:1 with boost and spray!
Old Apr 3, 2009 | 12:46 PM
sixltrbtr's Avatar
I just got my wide band in and at WOT it's around 9.5 to 9.8 no spray. I spoke with my friend who I got the truck from and he said the tuner set it rich for nitrous. (Magnacharged LQ9). I can only assume the tuner thought this would be a dry shot but it has an HSW wet plate on the truck. Thoughts??? I plan on running a 50 shot.
Old Apr 3, 2009 | 01:37 PM
krambo's Avatar
Too rich IMHO even with spray. I am surprised that your truck doesn't break up or foul plugs at those AFRs at WOT.
Old Apr 3, 2009 | 04:14 PM
it should be cuttin up bein that rich. find some place else and get it tuned right
