need help running rich after nitrous install
I just installed a nx mainline kit and before I even turned it on my fuel trims started running rich. Bank 2 at idle is off by 4-5% from bank one. I changed the plugs and took it out for a run. I am only running a 75 shot and honestly I expected more but i could feel it. my tuner said no more then 75 until we dyno tomorrow. Anyway has anyone experienced running rich after install.
Before I hooked it up I was -3 at idle and 0 at 2500. It was dialed in. Now I am -11 at idle and that is with the system off.
I appreciate any help. thank you.
make sure your fuel solenoid isnt leaking...also if you changed plugs, make sure all cylinders are firing. the water bottle trick works great. installing a nitrous kit shouldnt change your N/A AFR.
Sorry it took me so long. I was able to resolve this. The system did not fully purge which caused it to go rich. My trims have gone back to normal. And once I got the jets worked out it is awesome. 125 is a far as I am taking it now. Although I did 397 to the wheels ona 75 shot. So that made me smile.
Thank you everyone for the help. Although I a going to clean the solenoids for good measure.
Next is a bottle warmer and a timing controller son I dont have to keep my timing so low during daily use. Any suggestions?
I would highly suggest one of the Lingenfelter LNC 2000 controllers. They are super simple to setup and very reliable units.
I f you are looking for something a little cheaper and you have access to HP tuners and are good with wiring you can do the IAT mod.
Here is a link to how to make it and how it works.
https://ls1tech.com/forums/nitrous-o...de-system.html
Trey
Trey
therock
Jul 25, 2015 09:23 AM
lxcoupe
Jul 21, 2015 02:12 AM
