need help on my nitrous??
i have a 00 5.3l silverado loyd elliots heads and cam package,longtubes, i have nos wet kit.. i have it pilled at 175 and the nitrous bearly hits.. truck runs 8.4's on motor and only 7.9 on spray..when i hit the nitrous it hits real soft..cant anybody give me some pointers on trouble shooting this..note* i have replace the nos soeloid, cause i thought that might be the problem..any help will be greatly appriecated..thanks
11 Second Truck Club
I would look over the entire system. You have the wrong jets, clogged line, low pressure, kinked line, clogged nozzle. Something is very wrong so it shouldn't be hard to find. 175 should feel like a world of difference so it isn't like you are just a hair off. Goodluck.
Good luck to finding the issue
i believe i have 67 nitrous and 38 fuel.. nos bigshot seleniods.. not pinched lines,no clogged line or fogger..if i take the fogger out and spray while im holding it, it almost blows it outta my hand..ive heated the bottle to like 1200psi and its still real lazy on the spray..i figured with all ive got done my truck should run mid 7's with ease on the spray..also could any of you guys tell me what pills i should be runing for 175.? also i think my tune may be messed up i havent yet dyno tuned it with a wide band yet.
I've never used nitrous on a fuel injected app with a nozzle. But I've always used N.O.S. kits with carb setups and the fuel jet was always bigger. I know back if the fuel solenoid stopped up or had trash in the line with the 250 h.p. jets in, it would barely hit and seem real lazy on my carb setup. May not be right but my guess is check the jets.
gavin2005
09-13-2015 09:04 PM
06murder
09-04-2015 03:54 PM
