need help finding TPS output wire..
Old Apr 29, 2012 | 12:47 PM
mcdad1979's Avatar
Default need help finding TPS output wire..
i need help in locating which color the TPS output wire is for my 05 silverado 4.8 i just bought a nx wet kit and TPS sensing switch. i have everything done except hooking up the the output wire to my switch.
Old Apr 30, 2012 | 08:49 AM
The_dealer's Avatar
Registered User
Take your multimeter, set it for dc voltage, and apart probing wire. With an assistant pushing the gas. The signal wire is the one you are looking for. Don't hold me to it but I think there's a 12v constant going to it as well
Old May 4, 2012 | 02:31 PM
Slow08's Avatar
as TheDealer said take a multi meter and turn you key to asccesory and it wont read 12v. It works on a 5v signal, and it will read 4.3-4.8 volts. It should be the pink wire.
Old May 4, 2012 | 03:13 PM
robert85's Avatar
MASS seller approved
Yea definitely don't rush and get the right one...I thought I grabbed the right one and burned my sensing switch up......so went easy way out and installed micro switch behind gas pedal and works flawlessly! Good luck with yours man...could you let me know which wire you actually grab?
Chavette
Oct 28, 2015 07:33 PM
chvy=power
Oct 20, 2015 09:08 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
