need help finding TPS output wire..
i need help in locating which color the TPS output wire is for my 05 silverado 4.8 i just bought a nx wet kit and TPS sensing switch. i have everything done except hooking up the the output wire to my switch.
Take your multimeter, set it for dc voltage, and apart probing wire. With an assistant pushing the gas. The signal wire is the one you are looking for. Don't hold me to it but I think there's a 12v constant going to it as well
Yea definitely don't rush and get the right one...I thought I grabbed the right one and burned my sensing switch up...
...so went easy way out and installed micro switch behind gas pedal and works flawlessly! Good luck with yours man...could you let me know which wire you actually grab?
Guest
Posts: n/a
I know on most GM DBW TB's the Green wire is Rising voltage and the Purple is the falling voltage and with most controller you could hook to either without a problem. It might be different for the trucks but just in case it's the same im posting up...
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
