Meth with N2O?
Old Aug 24, 2006 | 10:00 AM
Default Meth with N2O?
Has anyone tried to run Methanol from a seperate fuel system with N2O?I know you would need to run about twice the fuel mixture for a give wet shot as with gasoline,but are there as other issues.
Old Aug 24, 2006 | 10:20 AM
dewmanshu's Avatar
Moderately Differentiated
I talked to kennedy's dyno out of new york about this last year and he said he does it with a few lightnings. he only mentioned what you mentioned about the extra fueling. he likes mixed meth (60/40) but says he definitely advises 100% meth in those scenarios for easier tuning.
Old Aug 25, 2006 | 07:24 AM
Av04's Avatar
I ran a dry 75 shot off my progressive meth controller with a powerdyne at about 8 PSI.it knocked 30* off my IAT's and dropped almost a second off my 1/4 times.The only problem is it was leaning out after 5400 rpm and you could here it knock.I only had one nozzle for the meth system which was good for 350hp(acoording to the manufacturer) so i think it was too small
Old Aug 25, 2006 | 02:58 PM
1BadAction's Avatar
Registered abuser
All the good 2 stroke Nitrous setups use Methanol as an enrichment fuel. burns cooler than gasoline and makes good power.
Mr. Chainsaw
Oct 18, 2015 08:00 PM
turbo6c3
Oct 5, 2015 06:11 PM
JordanH
Oct 3, 2015 03:59 PM
old motorhead
Sep 29, 2015 08:22 PM
gavin2005
Sep 13, 2015 09:04 PM
