Lost with questions
Old Feb 17, 2009 | 07:52 PM
outlawz2004's Avatar
Default Lost with questions
Ok, got NX solinoids with 48/30 jets for a 100 shot. Is this ok for a 4.8L.
Are relays neccessary on a simple setup like this with just fuel and nitrous solinoids, WOT switch, or just ground and positive ok. I plan on swapping the wot switch for a simple push button switch so that I can have better control on when it hits. For the fuel hookup on the fuel rail, where does it go. Is that the spot on the silver rail where you can pressure test it? Where does the nozzle go for a wet kit, before or after MAF being that it is spraying both fuel and nitrous. I would quess close to the throttle body but that could be very wrong.LOL. Anyone have some pics of nitrous setups so I can get a better idea of where everything goes.
Old Feb 17, 2009 | 08:02 PM
A Low Dime's Avatar
13 Second Truck Club
48/30 sound close to 100 shot. Yes, you need to add relays, I believe the solenoids draw quite a bit of power. You do not want that much power running in between your on/off switch. The test port on the fuel rail is where you can tap for fuel. You need a valve stem tool to pull out the schraeder valve that is inside the port. That is like a 5 dollar tool. A wet nozzle goes AFTER the MAF, somewhere around 6 inches away from throttle body.
Old Feb 17, 2009 | 08:09 PM
tikkigodman's Avatar
Too add to his question..ive ran about 25 bottles thru my 4.8 @ 75hp,wet setup.do you think he should pull some timing for the 100 shot?i havnt for the 75 but my manufacturer suggested 2deg for the 100.
Wheatley's Avatar
Truck Sponsor
Yes use relays
Old Feb 18, 2009 | 07:49 AM
slowprocess's Avatar
A few variables there...........what is your timing set at for wot? What octane are you running when you are spraying? On my 200 shot, I was running about 27 degrees with race gas and no knock. Doesn't work for everybody, but it worked pretty good for me.
Old Feb 18, 2009 | 05:51 PM
Charlie is going to pull 3 degrees out of it I believe.
Old Feb 18, 2009 | 06:08 PM
i figured.probly the safest bet,i wont move up until a timing change...
and slow,not sure on my wot timing and i always spray with 91-93 in the tank @ 900-1000psi.what would the easiest way to check my timing be?should i invest in a timing light?
Old Feb 18, 2009 | 06:29 PM
anyone have a bottle heater, switch panel, nitrous pressure guage, nitrous filter, or relay for sale?Pm me if you do.Also, anyone know the part number for the correct TR6 plugs that I need.
Old Feb 18, 2009 | 07:15 PM
Truckshop's Avatar
i have a box full of relays. how many do you need. come by the shop and get them if you want. you can get the plugs from thunder. about 20 bucks.
Old Feb 18, 2009 | 10:29 PM
I wouldn't sweat a nitrous filter. I've been spraying for 5 years now without one and haven't had any problems. I've also installed countless nitrous kits without a filter with no problems as well. I'll check with my buddy.........he was selling his nitrous setup and may still have his bottle heater.
