Lost with questions
Ok, got NX solinoids with 48/30 jets for a 100 shot. Is this ok for a 4.8L.
Are relays neccessary on a simple setup like this with just fuel and nitrous solinoids, WOT switch, or just ground and positive ok. I plan on swapping the wot switch for a simple push button switch so that I can have better control on when it hits. For the fuel hookup on the fuel rail, where does it go. Is that the spot on the silver rail where you can pressure test it? Where does the nozzle go for a wet kit, before or after MAF being that it is spraying both fuel and nitrous. I would quess close to the throttle body but that could be very wrong.LOL. Anyone have some pics of nitrous setups so I can get a better idea of where everything goes.
13 Second Truck Club
Too add to his question..ive ran about 25 bottles thru my 4.8 @ 75hp,wet setup.do you think he should pull some timing for the 100 shot?i havnt for the 75 but my manufacturer suggested 2deg for the 100.
A few variables there...........what is your timing set at for wot? What octane are you running when you are spraying? On my 200 shot, I was running about 27 degrees with race gas and no knock. Doesn't work for everybody, but it worked pretty good for me.
i figured.probly the safest bet,i wont move up until a timing change...
and slow,not sure on my wot timing and i always spray with 91-93 in the tank @ 900-1000psi.what would the easiest way to check my timing be?should i invest in a timing light?
anyone have a bottle heater, switch panel, nitrous pressure guage, nitrous filter, or relay for sale?Pm me if you do.Also, anyone know the part number for the correct TR6 plugs that I need.
i have a box full of relays. how many do you need. come by the shop and get them if you want. you can get the plugs from thunder. about 20 bucks.
I wouldn't sweat a nitrous filter. I've been spraying for 5 years now without one and haven't had any problems. I've also installed countless nitrous kits without a filter with no problems as well. I'll check with my buddy.........he was selling his nitrous setup and may still have his bottle heater.
