knock sensor pulling timing for nitrous
Old Jan 7, 2011 | 06:55 PM
6789olds's Avatar
Default knock sensor pulling timing for nitrous
on a older 5.7 vortec if i was spraying nitrous and the engine started to ping from not pulling timing from the tune would the knock sensor kick in and pull the timing for me ??
Old Jan 7, 2011 | 06:56 PM
viciousknid's Avatar
Where's the Beef?
If you don't melt a piston and blow it up first... Possibly. Tune it or get something that will pull timing properly.
Old Jan 7, 2011 | 07:00 PM
6789olds's Avatar
lol thats what i figured .hey do you know of a nitous timing retard that will work with my engine ? i seen one from harris but it only list back to the lt1, ls1 , ect.... it works threw the iat sensor ?
Old Jan 7, 2011 | 07:01 PM
Where's the Beef?
I was going to suggest the one for the IAT sensor but not sure where your sensor is, if you have one, or how it works.
Someone should chime in that knows.
Old Jan 7, 2011 | 07:13 PM
6789olds's Avatar
yes i have the iat . there is the filter , iat , mass air , throttle body .in that order .
Old Jan 7, 2011 | 07:29 PM
Where's the Beef?
wasn't sure if yours was on the tube or the intake manifold itself. May be a way to do it. If not there should be a timing tuner for it.
Old Jan 7, 2011 | 07:41 PM
6789olds's Avatar
yeah its on the tube . i would think it should work
OHsixLS3
Dec 27, 2016 09:30 AM
ullose272
Aug 5, 2016 02:05 PM
The_W
Oct 28, 2015 09:00 PM
Ls3silverado
Jul 31, 2015 04:22 PM
04450r
Jul 30, 2015 02:04 PM
